St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Very cool video. Thanks for sharing. I would love to do something like this but there is no way I can hold the camera and shift gears and drive too. I have got to get another arm somehow. I think I can make a mount for the camera at the where the top should mount.
That vid is . What exhaust is on your car? sounds good.
I knew this would come up eventually... here is the highly complicated rundown...
factory manifolds, 2-1-2 with converter and no mufflers. The mufflers were showing some good rust and I'm still deciding on a new dual setup sooooo I just hacked off the mufflers. it's surprisingly quiet meaning the converter is surprisingly restrictive! Most of that sound is intake noise.
I've followed a lot of lars advice as far as redoing my advance curve and setting the secondaries up on the carb. So far so good... unfortunately this one is starting to leak a little bit.
Eddie I have pictures on my webpage how to mount it to the holes in the pillar for the soft top but Troy's software sucks *** so you can't view it. Basically where the left hole is take a bolt that threads to the bottom of the camera body and place 2 nylon washers on either side to protect the chrome, then with 2 nuts 1 to tighten bolt to car and other camera body to bolt, easy sets up in 30 seconds.
