Starting Problem
Old Sep 13, 2004 | 06:37 PM
Texaggie's Avatar
Texaggie
Default Starting Problem
Our '72 convertible won't start. I turn the ignition to start and there is silence. My voltmeter tells me that the battery (Optima red top) has 14 volts across the terminals. Just to be sure I connected the charger to it and tried starting again.....nothing but silence when I turn the key. Can anyone suggest how I go about determining where the fault is?
Many thanks
Old Sep 13, 2004 | 06:42 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Auto or manual?
If auto, then try starting in Neutral. If 4-speed, check the starter kill switch on the clutch pedal. Let us know!
