Power steering pitman arm #
Old Sep 14, 2004 | 08:49 PM
GPVETTE's Avatar
GPVETTE
Cruising
Default Power steering pitman arm #
I have a 68 convert, 327 car. I think it had been converted to power steering by previous owner. I think the steering is too fast, in that it takes very little turning of the wheel for the car to respond dramatically. Feels very darty and like th rear end is trying to come around.
Considering how they did the power brake conversion (I returned it back to manual), I imagine that corners were cut here as well, and it makes sense that the manual steering arm would be a longer arm than power steering resulting in this problem. Could anyone supply me the part numbers for manual and power steering pitman arms for my application? (And if it's one in the same, I guess I shouldn't get out of my 69 Grand Prix, 70 Le mans or 54 Packard and jump in the Vette!!!)
KV
PS I'm a Pontiac restorer of many years and do lack a familiarity with the Vette. (But hey Pontiac never made anything likethe 68-73 Vette!!!) ANyone out there in NE PA near Scranton that could help sort this car out and see if it's the car or ME!
Old Sep 14, 2004 | 09:12 PM
redvetracr's Avatar
redvetracr
The "manual" steering pittman arm ends in #451
...redvetracr
Old Sep 15, 2004 | 05:00 AM
RHD '68 L89's Avatar
RHD '68 L89
The pitman arms should be the same for Power and manual.
For power GM moved the tierod end to the inside position to give a faster ratio. A Vette is not supposed to handle like a 69 Grand Prix (I have a 68 Bonneville) and will feel very direct compared.
Old Sep 15, 2004 | 08:24 AM
GPVETTE's Avatar
GPVETTE
Cruising
So the pitman arm just has to be at the inside position, and both arms the same? I'll check it out and make sure it's set up that way.
KV
Old Sep 15, 2004 | 08:40 AM
GTR1999's Avatar
GTR1999
PS and manual steering cars use different pitman arms. The boxes are the same. PS cars only use the forward hole in the knuckle,the other hole is plugged at the factory.
Gary
Old Sep 15, 2004 | 08:41 AM
GTR1999's Avatar
GTR1999
The picture below is of a PS arm.
Gary
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
They are close, but they are definitely not the same. I found this one out on my own when I converted my non ps car to ps. With the manual pitman arm you have no control over the steering when you get over center or at least that is what happened on my car. I traded a manual pitman arm for a power pitman arm and changed nothing else and the ps worked as it should. There is slight difference in the angle from the box to the control valve. I didn't think it would make a difference either.
Old Sep 15, 2004 | 05:12 PM
RHD '68 L89
OK, if they are different, what is the exact difference. You learn something every day!
Before I converted to rack I installed power on my Vette when I did the original RHD conversion. I used a RHD 64 chevy pitman arm because GM doesn't make a RHD Vette one. It was the mirror of the vette manual one and it all seemed to work fine.
Old Sep 15, 2004 | 05:39 PM
GTR1999's Avatar
GTR1999
Here are 2 boxes I rebuilt. Left is 72 w/PS, the right one is a late 69 wo/PS.
Here's the non PS arm
another of the two
Old Sep 15, 2004 | 08:53 PM
GPVETTE's Avatar
GPVETTE
Cruising
HEy thanks for the help, esp the pics, GTR 1999.
The tie rod is in the wrong place, currently located in the more rear hole. Will switch tomorrow. Car was obviously converted since there is no rivet in the rear hole.
The Ptiman arm is likely aftermarket, since it has no GM part number cast in it. SHould I assume it is part of the conversion kit? WIll print up the pics to see how close it is to the GM stuff.
Probably better off getting the GM part? Anyone have one for sale?
Thanks for all the help.
Old Sep 15, 2004 | 09:03 PM
GPVETTE's Avatar
GPVETTE
Cruising
From a close inspection, I think the PItman arm is OK. It has the steep drop at the control valve end. Makes sense that it's too fast right now inthe rear spindle mount, being a longer lever. Should help quite a bit, as will new rear spindle support rods, since those bushings are shot. I'lll give the final result tomorrrow.
Thanks again.
KV
Old Sep 16, 2004 | 08:06 AM
GTR1999's Avatar
GTR1999
good luck with your vette.
Gary
Old Sep 16, 2004 | 07:14 PM
GPVETTE's Avatar
GPVETTE
Cruising
GOt the arm changed to the right position but the final results will have to wait...Toe is so far out it squeals the front tires over 10 mph. And I'll have to change the control arm bushings first, so we'll see in a week or two.
KV
To Power steering pitman arm #
