Optima batteries... Alternatives???
Old Sep 15, 2004 | 03:13 AM
i885744's Avatar
i885744
Default Optima batteries... Alternatives???
Optima must have the smartest people alive working for them. My warrantee expired just 3 months ago on my red top. My battery is officially dead. It wouldn't hold a charge, it dies even with the alternator running. And the people at sears tested it bad for me. Should I buy another optima? What other brands are there? I run a big stereo (1 400 watt amp, and 1 600 watt amp), and a msd 6AL and MSD blaster 2. What other batteries are out there? I can't go any bigger in size than the optima. Thanks, Mike
Old Sep 15, 2004 | 05:29 AM
Love My 72 and 77's Avatar
Love My 72 and 77
do you think a different battery would have held up to that stereo abuse? I bought a car with a kragen Exide battery that has lasted a long time but I don't buy anything but optimas
Old Sep 15, 2004 | 05:39 AM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Since you have a heavy drain on the battery with all that stereo stuff,
why not get a SECOND battery with a switchable charging system to power the boom box?
Dep
Old Sep 15, 2004 | 06:08 AM
Twin_Turbo's Avatar
Twin_Turbo
Optima has the worst warranty ever. My battery which I hardly used just went dead sitting on a shelf, I did periodically charge it with a professional charger. The valve in mine went bad so half of the cells went dead. They kept saying I overcharged it but that's impossible with the charger I have.
They are good batteries as long as they are OK, just don't expect Optima to step up when it comes to warranty
Old Sep 15, 2004 | 11:55 PM
i885744's Avatar
i885744
Dep
Where do i suggest putting a second battery? The other bin houses my emergency equipment. Fire extinguisher, hydraulic jack, tire iron, small tool kit, some wiring accessories. I'm not getting rid of any of that stuff.
Old Sep 16, 2004 | 12:02 AM
jn76vette's Avatar
jn76vette
St. Jude Donor '08
How many amps does your altrenator put out?
Old Sep 16, 2004 | 12:11 AM
Schmucker's Avatar
Schmucker
Make a couple battery boxes to go under the rear, then cut out the stock bins, move the frame rails in, tub it a bit...
Optimas aren't that great. Mostly just marketing. I don't really know what to get to hold up to the increase strain from a stereo. I usually try not to get anything with less than a 72 month warranty and a 2 year free replacement.
Old Sep 16, 2004 | 12:22 AM
i885744's Avatar
i885744
i've got a 100 amp alternator, its only a few months old. My optima won't even take a charge. I put it on my charger and it reads full. Even when the battery is totally dead
Old Sep 16, 2004 | 12:52 AM
jn76vette's Avatar
jn76vette
St. Jude Donor '08
I'm guessing that even with the 100 amp altrenator that the system is underpowered. An even bigger alt. may be necessary. The local state police have a Camaro (i should add this car didn't leave the factory as a police car it was convered into one) pursuit car that has the same problem. With all of the lights, radios on, and the engine running, the battery dies in about 20 minutes. The alt isn't putting out enough amps to run the epuipment so the system draws from the battery. Total system voltage went from 14v to 9.5v in about 20 minutes, engine running. It has left the car stranded at many stops and accident scenes. We told them it needs a higher amp alt., Chevy dealership said a bigger battery. Even though we had tested the entire electrical system and conclusively shown it was the alt., they went with the dealers desicion. Well, four months and 3 batteries later. They put on a high output alt. no more power problems.
P.S.The Chevy dealer here in town couldn't diagnose a bad knock sensor in an LS1 either.
Old Sep 16, 2004 | 01:02 AM
jn76vette's Avatar
jn76vette
St. Jude Donor '08
You have a dead cell.
I have had a very good luck with interstate batteries, they have a great warranty.
Stay away from Napa batteries. We sell both at my parents shop, for every inerstate battery that goes bad, we get four or five bad napa batteries.
Old Sep 16, 2004 | 03:00 AM
stickboy's Avatar
stickboy
With the big stereo you may want to try optimas deep cycle battery (yellow top, I think). If you look at Optima's warranty it clearly states that a large stereo will void the warranty, not a good sign. FWIW I'm happy with my red top, though I've only had it for 6 months.
Old Sep 16, 2004 | 04:22 AM
randy814u's Avatar
randy814u
;I have had a very good luck with interstate batteries, they have a great warranty.
Stay away from Napa batteries. We sell both at my parents shop, for every inerstate battery that goes bad, we get four or five bad napa batteries.;
Just a side note, Interstate, and optimas are made by the same company, johnson controls, and napa batteries are made by excide.
We picked up the sears account sometime back, because they had to many returns from excide. The plant I work at does not make the optimas but they go through our shipping dept, but I do make the Interstate. randy
Old Sep 16, 2004 | 04:35 AM
i885744's Avatar
i885744
its not that huge of a stereo (or as dep would call it, my ricer "boom box"). I only have 1 8" sub, and 6 speakers. The front 4 speakers all fit in the dash and kick panels. The sub and the rears tuck nicely away in the back. I removed my 400 watt amp and am now driving them off of the head unit, they sound just about the same and draw less power. Anyway, even with running 400 watts less of power the car still has the same symptoms. I looked at yellow tops at sears, and they look like a good deal, but I'm concerned about their warrantee. The red top has a 3 year, while the yellow has 1 or 2, i can't remember. I have the same alternator in my 71 el camino, which has even more of a stereo with the same ignition setup, and it runs fine, so I'm pretty convinced its not the alternator.
Old Sep 16, 2004 | 09:17 AM
DJ Dep's Avatar
DJ Dep
Perhaps before tossing everyone's suggestions, you might MEASURE how much amps that boom box (and I never said RICER boom box) is drawing down. Take you car in to a reliable repair shop and ask them to check out the problem.
And a second battery with an automatic switchable relay is NOT brain surgery to install (Schmucker took the extreme route). Certainly a lot easier than installing all that audio stuff.
Dep
Old Sep 16, 2004 | 09:27 AM
Stoge's Avatar
Stoge
Do you have a capacitor inline with the +12v lead to your amps? If not I bet it would help.
Old Sep 16, 2004 | 04:27 PM
i885744's Avatar
i885744
bought a yellow top optima. Problem 100% solved.
Old Sep 16, 2004 | 04:47 PM
marshrat99's Avatar
marshrat99
[QUOTE=jn76vette]I have had a very good luck with interstate batteries, they have a great warranty./QUOTE]
I've got Interstates in my vette, two trucks, wife's and daugher's cars. They're about 3 years old and no problems yet.
To Optima batteries... Alternatives???
Old Sep 16, 2004 | 08:24 PM
crazcorkath's Avatar
crazcorkath
I think the Sears Die Hard gold battery has a better warranty than the optima and it costs a lot less. The die hard has either a 2 or 3 year free replacement and after that it is prorated for up to 5 years. It opnly costs $85. Th optima costs what---$130.
Old Sep 16, 2004 | 09:58 PM
1969c3mandy's Avatar
1969c3mandy
my optimas red top is just fine . I have a ten disc cd player and an amp running to the spaeker bar and front speakers. I ran through batteries like a champ every 12-18 mo.
then I changed the alternator...
Old Sep 18, 2004 | 02:38 AM
Solid LT1's Avatar
Solid LT1
Optimas SUCK! I had 2 go bad after pro-rated warranty period of 2 yrs (red top batteries) but, luckily for me, the manager of the Speed Shop where I bought them, warrantied them anyhow. I currently use deep cycle racing batteries and have had great luck with my Odessey brand of race cell (they will even recover if you don't trickle charge them during storage.) I would install a high output alternator if I was into high output stereos, or EFI in my Vette. Here is a link to their site:
http://www.odysseyfactory.com/default.htm
