*update* ever see a pushrod do this?
Old Sep 15, 2004 | 05:46 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default *update* ever see a pushrod do this?
Old Sep 15, 2004 | 05:50 PM
Boofers's Avatar
Boofers
What the??? How did that happen?
Old Sep 15, 2004 | 05:57 PM
Corz's Avatar
Corz
I honestly have no idea, I was cruisin along.. gave it a little gas and all of a sudden I get a HUGE backfire.. then it sounds and runs like crap.
I get the car home, tighten up the exh gaskets just to see.. start it up.. still actin funny. pull the valve cover off to see this
big pic
notice a pushrod missing?
then saw this
so I'll know more when I get the head off later tonite
Old Sep 15, 2004 | 06:00 PM
Fevre's Avatar
Fevre
Was the rocker off when you took the cover off?
BTW Get rid of the locking nuts and get some poly locks.
Old Sep 15, 2004 | 06:11 PM
burners's Avatar
burners
Cruise-In V Veteran
Yep, I've seen that before. Loose rocker arms will add enough slop to bend a pushrod. I had it happen just a few months ago with our parts hauler vehicle. Everything should be fine as long as a visual inspection checks out. Look at the lifter and the rocker cup.
Old Sep 15, 2004 | 06:15 PM
Twin_Turbo's Avatar
Twin_Turbo
check the locknuts, the 2 affected ones are probably loose, they should not be reused after removal but some people do...when they are not locking properly they can back off.
Old Sep 15, 2004 | 06:25 PM
BatManFire's Avatar
BatManFire
Had one bent as bad if not worse.
Old Sep 15, 2004 | 06:29 PM
stingr69's Avatar
stingr69
Maybe a nut backed off or maybe some interfearance in the valvetrain will do that too.
-Mark.
Old Sep 15, 2004 | 06:34 PM
lostpatrolman's Avatar
lostpatrolman
polylocks wont fit under the stock aluminum vavle covers unless you grind the crap out of it. I had to grind those oil deflector things off the inside of my valve covers.
Old Sep 15, 2004 | 06:41 PM
Corz's Avatar
Corz
nope.. it was on..
as for poly locks, no thanks. this engine aint that serious.
Old Sep 15, 2004 | 06:50 PM
Daytona69's Avatar
Daytona69
Similar thing happened to me, just no broken ones...had a couple of nicely bent rods though.
Old Sep 15, 2004 | 08:28 PM
tshort's Avatar
tshort
CI 7-8 Veteran
What is this, pushrod week?
I just broke 3!!! Broke the very tips right off where they meet the rockers. And they were the solid one-piece type. Oddly enough, it started ticking very bad for about 10 seconds and then it went away. I drove the vette home from the dragstrip with no problems and thought I just had to readjust lash. Just for ***** and giggles I popped off a couple of the rockers and sure enough, Bingo!
Old Sep 15, 2004 | 08:38 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
guideplates would help preventing pushrod breakage...
Old Sep 15, 2004 | 08:44 PM
Daytona69's Avatar
Daytona69
That's exactly what I had done I pulled both heads after the bent rods were discovered and sent them out for a complete rebuild with guideplates.
Old Sep 15, 2004 | 08:55 PM
Corz's Avatar
Corz
guide plates wouldnt have prevented a bent rocker arm stud
Old Sep 15, 2004 | 09:03 PM
vader86's Avatar
vader86
Somethings not right in the valvetrain elsewhere too then, only time I've seen that is when the piston smacks the valve. If the valve springs are new and you havent floated them, this shouldnt happen.
Old Sep 15, 2004 | 09:10 PM
Corz's Avatar
Corz
pulled the head off, here's what I found
NOTHING!
the bitch is goin back together friday
To *update* ever see a pushrod do this?
Old Sep 15, 2004 | 09:11 PM
vader86's Avatar
vader86
Id check the timing chain just in case, it might have lost a tooth or something.
Old Sep 15, 2004 | 09:14 PM
Ex_F-Body_Enthusiast's Avatar
To get the extra clearance for polylocks and/or roller rockers, you can try doubling up the valvecover gaskets by glueing them together with 3M Trim Adhesive or get the Felpro fatties. . .
Old Sep 15, 2004 | 09:51 PM
Glensgages's Avatar
Glensgages
Did the cam wipe-out a few lobes?
