rear leaf spring...paint
Old Sep 16, 2004 | 10:00 PM
cryzko's Avatar
cryzko
Default rear leaf spring...paint
well,
i have managed to have some of the rear suspension parts chromed and powder coated (black/green)... i have no clue what to do with the spring........ i know the chrome might crack but will the powder coating crack also.... i'm thinking about painting it with that flex additive that is used for urethane bumpers.... any suggestions
cryzko
detroit
Old Sep 16, 2004 | 11:07 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
I am in the same situation. I want to repaint my new steel spring (becaust the original paint is crap). Need a paint with very high abrasion resistance. Right now I'm thinking that is catalyzed paint or powder coating.
Old Sep 17, 2004 | 04:47 AM
i885744's Avatar
i885744
powder coating will rub off due to the leaves scraping and moving against eachother.
Old Sep 17, 2004 | 08:15 AM
stpman's Avatar
stpman
If that's the case then there isn't a coating made that will
Old Sep 17, 2004 | 09:30 AM
75 Hot One's Avatar
75 Hot One
I would never chrome plate a spring. It may become brittle due to absorption of hydrogen during the plating process. Failures have been reported. Using plastic liners between leaves should minimize wear on other types of coatings.
P.S. Of course if the car is for show only, it doesn't matter if the springs are brittle.
Old Sep 17, 2004 | 09:54 AM
72LS1Vette's Avatar
72LS1Vette
Paints like POR-15 and Rust Bullet are supposed to be pretty abrasion resistant and flexible. Color choices are somewhat limited but either one can be topcoated with another color paint. You would also have the added benefit of rust protection.
Rick B.
Old Sep 17, 2004 | 12:00 PM
stingraymaniac's Avatar
stingraymaniac
i painted mine with Wheel paint a couple of years ago
looks as good as new still.
heres a pic but its not that good.....
Old Sep 18, 2004 | 02:19 PM
ettev's Avatar
ettev
Fiberglass spring painted with Krylon. Still looks good after several years of casual driving.
Old Sep 18, 2004 | 06:55 PM
TJefferson2020's Avatar
TJefferson2020
I thought you weren't supposed to paint a composite spring due to the solvent weakening the resin - maybe vansteel will chime in on this...
pm
Old Sep 19, 2004 | 10:01 PM
fastback01's Avatar
fastback01
Cruising
Default rear leaf spring - paint
Try using a sponge and good ole rustoleum.......it works.....no problems.......
To rear leaf spring...paint
