Reuse pushrods?
Old Sep 18, 2004 | 12:08 AM
Brettmc's Avatar
Brettmc
Default Reuse pushrods?
On a cam swap, can I reuse my pushrods as long as I keep them with the same rocker arm?
Brett
Old Sep 18, 2004 | 12:16 AM
comp's Avatar
comp
can ,,,but if you can afford it put new in
Old Sep 18, 2004 | 12:18 AM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Can be done but they are cheap/easy compared to replacing the cam. Not worth taking a chance reusing them IMHO.
Good Luck w/the project!
Old Sep 18, 2004 | 12:19 AM
Brettmc's Avatar
Brettmc
In that case, should I get new roller rockers too?
Brett
Old Sep 18, 2004 | 11:34 AM
joe73vette's Avatar
joe73vette
Why would pushrods affect the cam? The only time I've seen them fail is at the rocker end, and that was because of either coil bind or the rocker nut backing off. Roll them on a flat surface and if they aren't bent, clean them up and re-use them. Joe
Old Sep 18, 2004 | 02:02 PM
stingr69's Avatar
stingr69
I have punched out a stock rocker and trashed a pushrod on a cam swap before. It is not that uncommon on higher mileage pieces that get a new cam with higher lift. The old wear does not like the new extra travel in the valvetrain and the cup blows out of the rocker arm.
I would agree that if the pushrods are straight and the ends are not worn I would keep the rocker mated to the pushrod and try to use them over.
-Mark.
To Reuse pushrods?
