Anyone do Keisler 5 speed
Old Sep 19, 2004 | 10:30 PM
timbo79's Avatar
timbo79
Default Anyone do Keisler 5 speed
Has anyone with a C3 one the auto to manual conversion using the Tremec 5 speed from Keisler. Ad in 'vette mag says 2899. a little high, but if all components are there.. might be worth it. 7 hour install?? (I lareadyu have a new crossmember from BowTie as I have a 700R4. With the TPI installed, I think the 5 speed and the 3:55's would be great.. Just hoping for some feedback from someone who has done it.
Thanks Guys
Old Sep 20, 2004 | 05:40 AM
Tomi72's Avatar
Tomi72
I believe that price is for the manual 4 speed to tremec 5 speed conversion, auto to 5 speed will be more expensive because of the clutch, bellhousing and pedal assembly needed.
I'm planning on doing the auto to tremec 5 speed conversion over next winter but I'll buy the parts locally and not use the kit. I think it will be a little more work but also a little cheaper.
Old Sep 20, 2004 | 07:45 AM
Gordonm's Avatar
Gordonm
I went from 4 speed to 5 speed so I can't comment on the price. The 3.55 gears should be great. I have 3.70s in mine and think it is perfect. My motor does not make a lot of low end torque so anything below 50 mph in 5th is useless. The trans is great and worth it.
Old Sep 20, 2004 | 08:38 AM
ram82fire's Avatar
ram82fire
I did the 700r to tremec switch and the results are great . There is no need for drive shaft work as the two are the same length . I gathered the required clutch components both from members here and ebay to install the hydraulics .
geo
Old Sep 20, 2004 | 12:16 PM
Beasley's 76's Avatar
Beasley's 76
Why 5 gears when you can get 6 for the same price! The T56 is the way to go, and you can buy one modified for C3's for around 2400, I believe Tremec carries it. I've purchased a T56 6 speed out of a 96 camaro and I plan on installing it over the winter. It's more work than the installing the modified T56, but I got it a good price. I hope to install the 6 speed myself with some help from some friends, I won't spend over 2K total doing the entire conversion.
Old Sep 20, 2004 | 02:37 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Becuase the T56 is longer, heavier, requires more modification to the frame, 6th gear is useless, TKO offers .068/ .064 while that 1:1 gear end sucks. Okay that's why.
Old Sep 20, 2004 | 07:36 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Telll em how you really feel
I've got a Keisler TKO 600 coming in the spring, would like to hear more about how easy it is going to befor me to install it in my garage.
Old Sep 20, 2004 | 08:05 PM
Gordonm's Avatar
Gordonm
I did mine in my garage on the floor. It was not to bad at all. I did cut the crossmember but after that it was a breeze. The TKO 5 speed fits very well. I have the .68 overdrive and with 3.70 gears it cruises down the highway at about 2200 rpm at 70 mph. Perfect for my motor.
To Anyone do Keisler 5 speed
