stiffer leaf spring
Old Sep 20, 2004 | 03:01 AM
cryzko's Avatar
cryzko
Default stiffer leaf spring
well,
i'm lower my 77 and instead of just using longer bolts, i was thinking of a stiffer spring with less of a curvature in it....... the problem with the longer bolts is that i don't want to run the chance of them hitting my tire/rim or hitting some debri on the road if i come across it. i figure that since i live near detroit then i shouldn't have a problem with finding a shop that does leaf springs...... i just need to know what i should look for..... 9 leaf/7 leaf or just do a composite......
cryzko
Old Sep 20, 2004 | 07:56 AM
Ganey's Avatar
Ganey
To upgrade the rear spring, you should also upgrade the front. VB composite rec. for less weight. Works fine w/ extended bolts.
