Heater won't work.
Old Sep 20, 2004 | 08:34 AM
copter's Avatar
copter
Default Heater won't work.
I tried it out this morning.I got no heat.The AC blows nice and cold.The fan works on both heat and Ac, but I got no hot air.Please help.This is an 82 CE.
Old Sep 20, 2004 | 09:44 AM
1970 Dave's Avatar
1970 Dave
Possibilities----temp adjusting cable--thermostat---heater core
SEMPER FI--1970 Dave
Old Sep 20, 2004 | 11:53 AM
copter's Avatar
copter
Ok.I'll look into those.I thought that all the temp comtraol were Vacume opertated?Where would the cable be.I did notice that when I turned it off it sounded like a door was shutting.
Old Sep 20, 2004 | 11:59 AM
Fevre's Avatar
Fevre
Check to make sure you have a heater core and it is hooked up by looking in the eng compartment for heater hose lines running to the fire wall. Then check to see if hot water is flowing to it.
Old Sep 21, 2004 | 08:24 AM
6318's Avatar
6318
When this happens to me...I turn on engine, place feet on floorboards...instant heat!!
Old Sep 21, 2004 | 09:09 AM
copter's Avatar
copter
Everything is hooked up.This car is absoultley unmolested so all the stuff is there.A lot of stuff I might add.I'm used to the older muscle cars with not much under the hood except the motor.
To Heater won't work.
