If I read the wiring diagram correctly, on my 1976 model the fuse for the horn is the 20amp stop lite fuse. I guess you could check for your stop lites and see if that is correct.
good luck
good luck
Thats the fuse I thought, but it is good. However my fuse for the AC/Heater is blown. Could it be this fuse???
What's the problem? You might get more answers if you stated the problem that is causing you to look for this fuse as the possible culprit. It might be something else besides the fuse.
Jeez! My horn doesn't work! All the wiring, horns, relays, and horn button are new, so I'm thinking fuse.
But does it matter, think of this as a Trivia Question:
In a 1977 Corvette, which fuse protects the horn circuit??
