Gas Tank Alignment (1980)
Old Sep 21, 2004 | 01:56 PM
MKearney's Avatar
MKearney
Default Gas Tank Alignment (1980)
I've lowered my body back unto the frame. The nozzle of the gas tank isn't sitting in the center of the hole in the body. Can someone look at their 80 Corvette and tell me if this is normal. I forgot to take pictures of this area before I lifted the body. The gas tank nozzle is nearer 12 o'clock than 6 o'clock.
Old Sep 21, 2004 | 02:09 PM
carnut114's Avatar
carnut114
When i put my 72 gas tank in with the body on my wife had to line in up straight from up top while i had to bolt it in.
Eric
Old Sep 23, 2004 | 08:02 PM
MIKER's Avatar
MIKER
Send me your email address and I will send you a picture of my gas tank nozzel position.
Mike
Old Sep 24, 2004 | 01:59 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I am pretty sure this is normal. The rubber boot that goes between the body and the filler neck has more room at the 6 o'clock position. In fact there is a drain hole down there. I am pretty sure the offset forward is at least 1 inch over center, if not more.
To Gas Tank Alignment (1980)
