Another Timing Question
Old Sep 22, 2004 | 02:55 PM
jacobsed's Avatar
jacobsed
Default Another Timing Question
I have a 350 out of a 72 Camaro in my 79 vette. I just installed a new compcam. I'm not an engine guru but learn quickly. What I have not been able to understand is how do I know what my timing should be? 8 degrees? 3 degrees? 5 degrees above or below TDC? Obviously I can look it up for a 72 Camaro and start there (assuming the cam change doesn't change it) but what determines this number and how can I figure it out for myself so I know it is correct? Wouldn't this new cam require a new timing setting? My balancer has 2224 stamped into it. I found that the timing mark on it is 10 degrees off from the keyway on the crank.
Old Sep 22, 2004 | 03:58 PM
Fevre's Avatar
Fevre
Check this out for performance timing, will work great for your eng:
https://www.corvetteforum.com/techti...=109&TopicID=3
Old Sep 22, 2004 | 07:19 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
I fully agree with Fevre,,,, this tech paper does wonders,,, and your instincts are also correct,, you can not go by factory specs with a hot cam. The fun part is when you get the thing all tuned write,, you'll be amazed!!!!!!
Old Sep 23, 2004 | 01:51 AM
comp's Avatar
comp
Old Sep 23, 2004 | 06:03 AM
jacobsed's Avatar
jacobsed
I have an HEI distributor so I'm not sure how that paper can apply.
To Another Timing Question
