Extra parts for '72
-=Boston!=-
Parts Listing:
Miles per hour reset cable and template
2
Light with vacuum switch
3
Air conditioner / heater switch
1
Complete console center dash gauge system
1
Tach gauge
1
Miles per hour gauge
1
Center console shift plate, vents *****, ash tray
1
Vacuum console switch
1
Distributor
1
Distributor grease unit
1
Distributor noise reduction plates / with screws
2
Tach adjuster
1
Heater core
1
Ignition coils
3
Vacuum advance for Distributor
1
Stainless steel parking brake kit
1
Horn cap and button
2
Gas pedal
1
Brake pedal
1
Hood lock assembly
1
Door mirror
1
Seat hardware
6
Weathering stripping
3
Dash pouch
1
Tee top bags
4
Door pull
1
Door opener
2
Door locks
1
Door lock electric celluloid
1
Chrome upper tee top brace
2
Tee top bar adjuster covers
8
Tee top lock covers
4
Tee top locks with key
2
Emblems, stingray, corvette, flags, name plate, name letters
Hood hinges
3
Lock cover
1
Light lens round
4
Light lens standard
2
Light lens blinker
1
Light lens marker
2
Seat *****
3
Headlights with chrome retaining rings
2
Headlight housing
2
Replacement halogen headlights
2
AC vents and brackets
3
AC housing units
3
Assorted body trim
Console lock
1
Console retainers
3
Window adjuster
2
Points and condensers
4
Spark plug set
1
Oil filter
1
Rear axle shim set
2
Door shim set
2
Tee top shim set
8
Wind-shield trim plate
1
Door panel trim plates
2
Door panel custom rug trim plates
2
Body lower chrome trim plates
2
Wind-shield wiper vacuum canister
1
Wiper arm assembly
Head light vacuum canister box
1
Vacuum pump assembly for wipers
1
Vacuum pump assembler
1
Rear axle spindle
1
Heater / AC blower motor
1
Assorted interior panels
Assorted hardware
Radio / tape player
1
Center wheel cap
1
CLICK HERE to see pictures of the parts.
The rear window alone is $100 for a decent one.
If you do buy the lot, I'd be interested in some rear marker lights.
Dave - in Burlington right now
