196hp Bye-Bye
Old Sep 24, 2004 | 02:00 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Default 196hp Bye-Bye
Just dropped my 80 off at SpeedTek...
Per the previous post...we made 196hp at the rear wheels about a month ago. Pick it up next Thursday with the 64cc RPM heads (polished and ported) and the XE274 cam installed.
Will post the new dyno numbers shortly there after...
Old Sep 24, 2004 | 02:32 PM
brooksman9's Avatar
brooksman9
St. Jude Contributor
Old Sep 24, 2004 | 02:40 PM
Corey_68's Avatar
Corey_68
You should see a nice improvement.
Old Sep 24, 2004 | 03:18 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Dammit, slow down. I can't keep up with your never ending pace.
How stock is was your motor before sending it in?
Old Sep 24, 2004 | 03:34 PM
standup's Avatar
standup
......How long before you get it back????????.........I'm interested in hearing about that cam.......
Old Sep 24, 2004 | 05:03 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Old Sep 29, 2004 | 09:12 PM
80TexasC3's Avatar
80TexasC3
Stock L48 block
Performer intake
650 Thunder Carb
Hooker Comp Headers
Hooker True dual with Flowmaster Delta 40s
Flame Thrower HEI
Old Sep 29, 2004 | 09:13 PM
80TexasC3's Avatar
80TexasC3
Spoke with the garage this morning...
Cam breakin and Dyno tune tomorrow morning.
I pick it up at noon... will post results tomorrow.
Old Sep 29, 2004 | 09:18 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Looking forward to the after results.
Old Sep 29, 2004 | 10:22 PM
Ak. Mal's Avatar
Ak. Mal
Originally Posted by 80TexasC3
Stock L48 block
Performer intake
650 Thunder Carb
Hooker Comp Headers
Flame Thrower HEI
Damn, our cars are closer than I thought. Mine has the performer intake, an Edelbrock Performer 650 and a set of headers. I also have dual exhaust, but no mufflers yet. Did the Flame Thrower HEI make a difference?
I know my engine has a real, real aggressive cam. I'm thinking about swapping it out for something closer to stock. My father in law (lifetime mechanic) thinks I should go back to the stock cam. I'm thinking a little more performance oriented. First I gotta figure out the specs on teh stock cam. Then we can decide where to go with that.
Old Sep 30, 2004 | 09:52 AM
80TexasC3's Avatar
80TexasC3
Don't know that I saw a difference with the Flame Thrower. Understand it helps at higher RPMs and has a cleaner burn.
Old Sep 30, 2004 | 11:27 AM
TTop Tony's Avatar
TTop Tony
should be interesting since I'm about to put the same heads on my car
Old Sep 30, 2004 | 11:31 AM
Stewart's74's Avatar
Stewart's74
Waiting............
Old Sep 30, 2004 | 01:54 PM
Shark Racer's Avatar
Shark Racer
The L-48 cam is absolutely horrible, especially considering you have a 4-spd. Powerband is 1600-3200 rpm. Odds are you tach much higher than that on the freeway - expect better fuel economy at cruise range going with a midrange cam.
My Crane 272 is a real nice cam - Pick something in the mid-to-high 210 range if you don't plan on changing out heads. Comp CS268 and Crane 272 are pretty close to the L-82 cam.
-Steve
Old Sep 30, 2004 | 04:53 PM
80TexasC3's Avatar
80TexasC3
OK... Drum Roll.........
Just picked the car up and LOVE the idle! Happend to arrive at Speedtek while they were doing a dyno run and I could not believe my ears!
Here are the before and after numbers:
BEFORE AFTER (XE274 and new RPM 64cc heads - ported)
HP 196.0 264.4
TOR 273.5 307.6
That's all at the rear tires! Calculating for a 20% loss from the flywheel that puts it at about 320hp at the flywheel! Not bad considering the car came out of GM in 1980 with 195hp at the flywheel.
Someone use the term "sheep to beast" in an earlier post. I couldn't agree more! Slow start...then full power breaks rear loose...once she grabs she continues to pull hard... shift to 2nd at 5,000 and rear comes loose slightly again! Can really feel the pull from around 2,500 to 5,000!
I'll post the dyno chart once I get home and can scan.
THANKS FOR ALL OF THE ADVISE FROM EVERYONE! THIS FORUM IS GREAT!!!
Old Sep 30, 2004 | 05:03 PM
Ak. Mal's Avatar
Ak. Mal
HOLY SNAPPIN' A-HOLES!!!! That great!
Let us know when you get your first ticket.
Old Sep 30, 2004 | 09:08 PM
80TexasC3's Avatar
80TexasC3
Hope not... Fastest 0 to the Speed Limit.... And a little rubber left behind. Just pulled it in the garage...think I donated about 10,000 miles of Goodyear to the Texas roads this evening....and only drove about 70 miles...
To 196hp Bye-Bye
Old Sep 30, 2004 | 09:56 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Did you uses the new Speedtek shop on 121. That is one nice showroom.
Old Sep 30, 2004 | 09:58 PM
80TexasC3's Avatar
80TexasC3
You Bet! Kyle helped me setup the system and Eric did the install/tune. Great guys, awsome shop and I will return for more! Very highly recommend them!
Old Sep 30, 2004 | 10:04 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
They wanted me to stop by and dyno the other day, but my schedule was booked. The have a very nice 69 LS1 Camaro. Shoot me an email next time your over there during the day and I'll bring to lunch at Angelos. Oh great to hear the car is running like a bat out of hell. Now it's time to go to the track and put down some times.
