Engine Mount Question
Old Sep 24, 2004 | 07:59 PM
40927's Avatar
40927
Default Engine Mount Question
In the next couple of weeks I will be installing a new 440 horse small block crate motor into my 71. Does anyone think I need to use solid motor mounts with that kind of horsepower or will the rubber/urethane mounts work fine?
Old Sep 24, 2004 | 08:03 PM
nastee383's Avatar
nastee383
Wouldn't use solids on a street car. Polyurethene mounts will easily handle that power and more. I wouldn't use rubber if you plan on beatin' on it at all.
Old Sep 24, 2004 | 08:05 PM
Gordonm's Avatar
Gordonm
No need for solid mounts. I am running the poly mounts on mine and the yare holding up fine under lots of abuse.
Old Sep 24, 2004 | 08:09 PM
MIKER's Avatar
MIKER
I used new rubber mounts when I installed my engine. Destroyed the drivers side mount in no time. Replaced engine and trans mounts with polyurethane mounts and they have held up fine so far.
Old Sep 24, 2004 | 08:14 PM
40927's Avatar
40927
That is what I was thinking but just wanted to check and see what everyone else is using. Thanks
Old Sep 25, 2004 | 07:53 AM
73jst4fun's Avatar
73jst4fun
To Engine Mount Question
