Radiator Hoses...??
Old Sep 25, 2004 | 04:25 PM
1970-Bronze's Avatar
1970-Bronze
Default Radiator Hoses...??
Are both the upper and lower hoses suppose to have internal supports (sprial wire)?
Mine doesn't have either. Has anynoe source them locally or am I going to have to order them...?
Old Sep 25, 2004 | 04:32 PM
diablo kid's Avatar
diablo kid
On a 1976 model the lower must have a spring but the upper doesn't need one. I understand that the water pump can suck the lower hose flat if it doesn't have a spring.
Old Sep 25, 2004 | 06:09 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
the water pump sucks from the bottem and if you dont have the spiral wire in the hos eit will collapse so be carfull and good luck. a replacement hose should come with one not 100% sure but i will find out soon sense i am getting new ones on the 15th.
Old Sep 26, 2004 | 08:27 PM
76REDSTINGER's Avatar
76REDSTINGER
i just replaced my lower, new hose did not have spring
i just pulled old one out and stuck it in the new one
Old Sep 27, 2004 | 11:35 AM
1970-Bronze
Has anyone found a lower hose with the spring locally?
My old hose doesn't have a spring for me to steal and use.
Old Sep 27, 2004 | 12:33 PM
markdtn's Avatar
markdtn
Pretty sure the Gates hose has the spring still. Available CarQuest, NAPA, O'Reilleys.
To Radiator Hoses...??
