L-48
Old Sep 25, 2004 | 04:54 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default L-48
What are some ways to get more horsepower out of a 75 L-48. The motor already has true dual exhuast, a eldlebrock intake, and a 650 holly carb on it. But I want a little more horsepower so what are some Ideas. Thanks
Old Sep 25, 2004 | 05:16 PM
Silver00V6Camaro
Also would like some specs on this motor thanks
Old Sep 25, 2004 | 05:19 PM
Schmucker's Avatar
Schmucker
The biggest problem is the heads. Get some small chamber heads to bump the compression back up and a cam to match and you'll be happy. It'll be fun, not too fast, but more like it should be. Which heads specifically? No idea. Someone else can chime in there.
Old Sep 25, 2004 | 05:27 PM
Silver00V6Camaro
Thanks Then what are some good heads and a cam for the motor and with stuff that is already done what might be an estimated hp/torque rating.
Old Sep 25, 2004 | 05:39 PM
PRESSURERAT's Avatar
PRESSURERAT
Horsepower is usually in direct relation to dollar amount. How much are you willing (or able in my case!)to spend? Intake manifold, cam and headers are usually the first add ons. Heads are probably the best way to add power but usually are expensive. Keep in mind, there are cases where rebuilding and or modifying used heads can cost as much as buying brand new ones. For the money, GM Vortec heads will work well with your stock cam and exhaust manifolds but require a different intake. Of couse there are many good cylinder heads out there, I hear Edelbrock aluminum heads are first rate. I am partial to factory performance heads because of their quality, fit ,and reliability. Do some research on the web and pick up some Hot Rod or Car Craft type magazines. There is a wealth of information out there on how to do just want you want. But like I said up front, how much you gonna spend?????????
Old Sep 25, 2004 | 05:58 PM
oregonsharkman's Avatar
oregonsharkman
A set of edelbrock rpm aluminum heads with a smaller chamber and a nice cam will help you out alot. you won't have to change your intake for the rpm heads, the smaller chambers will increase your compression ( L48=8.5:1 CR ) also aluminum heads allow more compression than iron heads for a given fuel quality------you might still be able to run 89 octane. And you will lose weight off of your car if you ditch the iron heads. there are many choices for cams out there, but you could always just make it easy and get the matching rpm cam (although I have never used one personally) But the rpm heads on my stroker 383 make bunches of power..........good luck
Old Sep 25, 2004 | 07:51 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Depends on your budget. If it's tight, a cam swap will get you the biggest bang for your $$. The L48's wimpy cam accounts for probably 90% of its hp deficit as compared to the L82. If your budget allows, as already suggested, new heads with smaller chambers (when combined with a better cam) could provide another substantial improvement.
Old Sep 25, 2004 | 08:01 PM
comp's Avatar
comp
long tube headers on that list
Old Sep 25, 2004 | 08:14 PM
Indynut's Avatar
Indynut
My idea, would be to have the distriibutor recurved (LARS) and then set the timing correctly (LARS timing paper). Most times, best things are also the most basic. I did the lowest cost things 1st. I found a used aluminum intake (Edelbrock Performer) for $25, then added the matching Performer Cam. Also added a nice set of headers. By the way, if you can find the orginal carb, the stock quadrajets actually flowed 750 cfm and once LARS works his magic on one of those puppies you'll be flying. Stock times on my L-48 equipped 1979 was around 15.9's and I've gone 13.96 at 98 mph with the stock 3:55 gears. But then BIG BLOCK fevor hit me.
Indy
Old Sep 25, 2004 | 09:52 PM
trotter73's Avatar
trotter73
I agree with the above comments, you can also
switch to an electric fan and a set of underdrive pulleys to free up some horses. And also put on some roller rocker arms.
Old Sep 25, 2004 | 09:57 PM
trotter73's Avatar
trotter73
L48 Engine
Item Description
Engine Chevrolet OHV V-8
Bore x Stroke 4.00 x 3.48
Displacement 350.00
Compression Ratio 8.5:1
Carburetion Four barrel carburetor
Horsepower 165@3800
Torque 255@2400
Distributor High Energy Ignition (HEI)
Old Sep 26, 2004 | 12:19 AM
62fuelie's Avatar
62fuelie
My L48 has the following mods and it will keep up with, or maybe out run my 67 L79:
Bored +.030
2.5" ramshorn manifolds and 2.5" exhaust, true dual-no cats
9.8:1 compression
cam change, not sure of specs, but almost anything would represent an improvement. Described as "street performance" cam
Edlebrock manifold and carb.
DUI distributor- not sure this is really necessary change, but it came on the engine.
Any and all pollution controls removed, ie air pump, etc.
Old Sep 26, 2004 | 12:41 AM
A78Corvette's Avatar
A78Corvette
http://www.73-87.com/chp/gm350.htm
This might help.
Old Sep 26, 2004 | 12:43 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Originally Posted by Schmucker
The biggest problem ARE the heads.
Old Sep 26, 2004 | 01:47 AM
comp's Avatar
comp
Bored +.030
9.8:1 compression
how much stronger is it Now???
Old Sep 26, 2004 | 02:21 AM
desi's Avatar
desi
Start with a good tune up. Rebuild carb and distributor according to Lars paper.
Add headers and exhaust.
Change Intake and cam.
If you can afford, change heads (and the right cam for new heads).
What kind of power do you have in mind?
Old Sep 26, 2004 | 02:24 AM
desi's Avatar
desi
Originally Posted by A78Corvette
A must read.
Read all the stages of mods and make notes of all hp/tq numbers with each mod. Then decide where you want to be. Very good article.
To L-48
Old Sep 26, 2004 | 07:57 AM
Ganey's Avatar
Ganey
Exhaust: http://www.corvettefaq.com/c3/ganeyexhaust.htm
Besides exhaust, actually what it really needs is more cam! Vetterodder is right.
When you rebuild is a good time for heads.
You need to give trans. & rear gears for cam.
Old Sep 26, 2004 | 12:51 PM
62fuelie's Avatar
62fuelie
Like I said, it is at least as strong as the 67 with the 327/350. This is in a 75 vert that is equipped with a 3.36 rear end. The 67 has a 3.70.
Old Sep 27, 2004 | 08:12 PM
Boofers's Avatar
Boofers
FYI - my engine is a stock L48, 100 000 miles and these mods:
-Comp Cams H268
-Weiand 8004 intake
-Hooker Competition headers
-2.5" dual exhaust with cats
-Magnaflow mufflers
-Recurved distributor mechancial advance as per Lars paper
-Richened the stock QJet with primary metering rods 4 sizes thinner & slightly thinner secondary rods
Dyno results - 237 rear wheel horsepower.
I estimate around 280hp at the flywheel, stock was 180hp.
Can't wait to get some decent heads onto her!!!
