if they both failed at the same time, i would probably start w/ the cluster first.
also, where are the needles at? full/max or empty/0? or are they resting in the middle?
u can check the opperation of the gauges my grounding the signal wire from the tank unit/pressure switch to see if it is a guage problem or else where.
