Header Heat?
Old Sep 26, 2004 | 01:18 AM
Joe Buck's Avatar
Joe Buck
Default Header Heat?
I just had some massive engine work done, which included Hooker headers, but I didn't have the $ to coat them. Since then, I've noticed a massive increase in the heat near the foot bed in my vette, what gives? Is it the Header, and would coating them help stop the heat?
Old Sep 26, 2004 | 01:45 AM
comp's Avatar
comp
yes and yes... there are also wrap's
Old Sep 26, 2004 | 10:29 AM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Headers put out a lot of heat. Best solution is Jet Hot on the headers and extra insulation UNDER the car along with UNDER the carpet.
Old Sep 27, 2004 | 07:28 AM
78pacer's Avatar
78pacer
Hey bro,
Join the 'hot foot' club. Have headers, will roast
Old Sep 27, 2004 | 09:29 AM
Boofers's Avatar
Boofers
When you put on headers it makes your engine breath easier and effectively leans out your A/F mixture. You should richen your carb which will not only give you a better tuned engine but will lower your exhaust temp and therefore your foot temp as well.
Definetely richen your carb before you put coated headers on because the higher exhaust temp from running lean will dull the ceramic coating. I know from experience...
FYI I found it didn't take long before the the header gaskets that came with my Hookers had blow byes and caused little tick tick ticking sounds from exhaust leaks.
Old Sep 27, 2004 | 09:56 AM
norvalwilhelm's Avatar
norvalwilhelm
I wrapped my headers more then 10 years ago. It really made a difference in under hood temperatures. I do not drive in the rain ever.
To Header Heat?
