I'm looking at a couple of early C3s with factory air conditioning. In both cases, the air conditioning has been removed but all the parts come with the car.
How much work in involved in re-installing the a/c components?
Need more information. What year car(s)? Is the condensor removed? Outer box/evaporator removed? Inner box removed? Compressor removed? Lines removed and system open to the air? If we know what is missing/wrong we can give a better answer to your question.
Well in my case, everything is removed and the firewall has been glassed over - to reinstall, would need to remove motor at a minimum, and if I did that, Id rebuild it or put a crate motor in, on top of the AC. So Ill keep dreaming for now...
If you want A/C, at least hold out for one that has the inside stuff still intact. I'd run from the others. They'll never be right and have zero resale value except to racers. They are however much lighter/faster, but typically also lack a heater. Engine side A/C install is easy. It's your choice...
Car in question is a '68 vert. Compressor and evaporator have been removed, but I gather interior bits & pieces are there.
Any opinions?
If not glassed over you can get the outside parts. Sounds like you need an outerbox/evap, hoses, compressor(/brackets?),condensor. Correct hoses are very pricey for a 68.
If it was me and you wanted factory A/C, I would get a later outside box (78-82). THen you can use later hoses and lines. You will still want to take the inside stuff out and re-seal it and put in a new heater core.
Parts estimate: Box/evap $100 used, hoses $125 new, high press line $25 used, condensor $161 new, compressor $100 rblt or $250 new,dryer $45 new, orifice tube $5 new, R134 $25 new.
Sorry -- to clarify -- the a/c was working when it was removed by the previous owner. All parts are included, so it should be a re-install and charge-up job. My question is how much labour that's likely to involve.
I'm mechanically declined, so it'll have to go to a professional. I'm also located outside the US, so Hot Rod Air isn't really an option.
If the inside stuff (controls, vacuum and electrical, ducting, heater core) is intact and you have the original engine side parts, it is a reasonable proposition. I'd guess 1 - 2 K to have a pro re-install it.
Adds about 5K to the value if it is original and it works.
