New driveshaft?
Old Sep 27, 2004 | 08:59 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default New driveshaft?
Would a "new" driveshaft need balanced? Guy I talked to at a local shop said not necessarily.
Old Sep 27, 2004 | 09:18 AM
stingr69's Avatar
stingr69
Not if it is in balance.
GM balanced your driveshaft when it was new. Replacements should be balanced in my humble opinion.
-Mark.
Old Sep 27, 2004 | 09:21 AM
norvalwilhelm's Avatar
norvalwilhelm
Any local shop making a drive shaft will automatically balance there shaft as a cost of about $45. roughly. It should be done. If you are buying factory there will be a small balance weight welded someplace on it.
Old Sep 27, 2004 | 10:46 AM
mandm1200's Avatar
mandm1200
I was under the impression that the driveshaft needs to be balanced. I would assume that a new driveshaft would be balanced from the manufacture, GM or aftermarket. I would just ask when ordering. If your getting a driveshaft re-done for some reason, it should be done and listed on the invoice as being balanced.
To New driveshaft?
