Re-torque heads after breakin?
Old Sep 28, 2004 | 08:59 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re-torque heads after breakin?
In order to reach the lower bolts would require removing the headers and/or exhaust manifolds?
How many actually remove the headers to get to the lower bolts? How many actually re-torque the heads?
Old Sep 28, 2004 | 09:03 AM
stingr69's Avatar
stingr69
I do not retorque. GM did not retorque even with steel shim gaskets. Modern composition gaskets do not need retorque.
JMO
-Mark.
Old Sep 28, 2004 | 11:36 PM
RAT502's Avatar
RAT502
Jug, you really should retorque, its a pain in the ***, but better safe than sorry...tech notes on that gasket are as folows: DO NOT USE SEALER AND RETORQUE AFTER ENGINES FIRST RUN.
To Re-torque heads after breakin?
