Since your exhaust isn't running under the car, you have enough room under your floor board for additional storage. Simple enough to build a bin (probably should be metal even though the frame protects it) under the floor, cut a square hole in the floor, add hinges & trim.
Good place for an amp, disc changer or video recorder was what I was thinking. Easier to get to then behind the seat... plus good for things that you want to keep out of the way during a show (especially if you are showing off the rest of your interior).
Anywhere you want on the driver or passenger floor or both... you really only have about 2 inches before it would extend below the crossmember.
Just something silly I thought about when seeing an ad for some minivan that had floor storage... so I won't be looking for royalties if anybody actually performs the operation.
I should have known better then to post it here on this board though... such low tolerance for any mods other then their own.
Will cutting a hole in the floor effect the integrity of the mounting brackets for the seats? I would hate for this to have an adverse effect on your safety if you hit something or someone hits you.
Yeah, a disc changer would be too large. After I posted about it, I went out to the garage and measured to see how far you could really go... only about 2 inches.
It's not a very good idea... not because of cutting a hole in the Holiest of Cars, but because of the potential for hitting road debris.
djunod, I should say that I'm happy you brought up a suggestion for modifying our cars though. It's always great to hear new ideas. If there was no one willing to do that this forum would be a boreing place. I just saw the opportunity for a joke and took it. Maybe I shouldn't have.
