Hot vs Cold plugs
Old Sep 28, 2004 | 11:43 AM
68coupe's Avatar
68coupe
Default Hot vs Cold plugs
Does anyone the difference between hot and cold plugs? How do you determine the heat range for your engine? I have 1968 327 bored 30 over with Edelbrock performer RPM heads 60cc, electronic ignition, what is a good spark plug for my car??
Old Sep 28, 2004 | 12:58 PM
Ironcross's Avatar
Ironcross
Since 44`s are no longer available the next best selection would be a plain R45 and not a R45S. R43`s will foul out during low speeds because that range is too cold.
Old Sep 28, 2004 | 01:08 PM
comp's Avatar
comp
with the alum. heads standard may work OK ????
Old Sep 28, 2004 | 01:31 PM
68coupe's Avatar
68coupe
Thanks for the responses!!!
What are the differences between R45 and standard. What does the S stand for in R45S? And which manufacturer should I pick? Delco? will these work with electronic ignition? what about the heat from the high compression heads? what is the heat range on an R45 plug? What about gap size??
Thanks,
Joe
Old Sep 28, 2004 | 02:03 PM
Ironcross's Avatar
Ironcross
I dont know exactly what a standard plug is. He may be refering to a plug with out a "R". However, R means resistor, which nearly all plugs are now classified as being. The "S" means extended tip that will protrude in to the combusion chamber sometime hitting the top of the piston on higher compression engines. The munbers refer to heat range, the lower # the colder the plug. 42,43,44, 45 ect. cold to hot. Street driven engines will react and stay cleaner with a 45 heat range. Use the R45 and gap it at .035 for point style ignition systems.
Old Sep 28, 2004 | 02:19 PM
68coupe's Avatar
68coupe
Default couple more questions
Taylor,
Thanks, for the great advice, ut I have a question for you. I think my comp. ratio is 11:1, should I stil use the R45? Also, in your response you said to use a .035 gap for points, but I have MSD ignition. Should I still use this gap or a different one. If a different one, what gap?What about manufacurer? AC Delco?
Thanks,
Joe
Old Sep 28, 2004 | 02:46 PM
Ironcross's Avatar
Ironcross
Originally Posted by 68coupe
Taylor,
Thanks,
Joe
AC plugs are a good quality plug. I suggested the AC R45 because I had no reference to your compression. At 11-1 it`s the best choice. With transistor ignition the gap is normally .040
Old Sep 30, 2004 | 05:23 PM
68coupe's Avatar
68coupe
WHen I went to the store to buy the plugs, they could not find them. They said that there are some nubers after R45. Any ideas???
Old Sep 30, 2004 | 06:21 PM
1979toy's Avatar
1979toy
Edelbrock recommends the Champion RC12YC plug for their cylinder heads.
Don't forget to use anti-seize!
Old Sep 30, 2004 | 09:59 PM
68coupe's Avatar
68coupe
Default question for you
Steve,
I noticed in your profile that you use edelbrock heads, do you use champion plugs?
If so, what is the heat rating on those?
Thanks,
Joe
Old Sep 30, 2004 | 10:30 PM
1979toy's Avatar
1979toy
The plugs that I use are the same one's that I mentioned above, the Champion RC12YC. Any good auto supply house should be able to cross referance that number to whatever brand that they sell. If they cross referance just the RC12 you will get a standard plug. The Y means that the plug has a projected tip and the C is for a compact, or shorter, plug. If you have headers you will want a short plug length most likely and you really want a projected tip. The Edelbrock heads use a gasketed spark plug.
Old Sep 30, 2004 | 11:16 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Edelbrock heads use a 3/4" reach plug (like the RC12YC), not the shorter plugs that stock heads use.
Old Oct 2, 2004 | 12:45 PM
68coupe's Avatar
68coupe
Default crosss reference
I went to Autozone and they cross referenced the plug with an AC Delco and it came out to 41-602.
DO you think this is correct???
Is the heat range 41??
Does a hotter range plug burn hotter and vice versa?
Please help!!
Joe
Old Oct 2, 2004 | 01:27 PM
PRNDL's Avatar
PRNDL
some good info here:
http://www.acdelco.com/html/pi_plugs_ident.htm
Old Oct 2, 2004 | 03:15 PM
1979toy's Avatar
1979toy
Looking at the link kindly provided by PRND21 I would have to say that the spark plug that they are trying to sell you is NOT the direct replacement for the Champion RC12YC. It may be the same general heat range as the Champion plug but does not have the projected tip nor the shorter overall length.
Old Oct 3, 2004 | 12:11 PM
68coupe's Avatar
68coupe
I returned the delco plugs and got the champion RC12yc instead.
Any suggestions before I install them?
Should I use anti seize?
Gap them .040??
Anything else I need to know??
Thanks for all of your great posts!
Joe
Old Oct 3, 2004 | 02:59 PM
1979toy's Avatar
1979toy
USE ANTI-SEIZE!!! ALWAYS USE ANTI-SEIZE!!! ON EVERY BOLT GOING IN TO THE ALUMINUM HEADS!!!
Should you ever forget the above warning, just one time, you risk destroying the threads in whatever hole that you failed to put anti-seize on the fastner.
I have an MSD ignition and gap my plugs at .035. You should be fine with that gap no matter what ignition you are using.
To Hot vs Cold plugs
