Let me just start by saying Dan at Van Steel is great to work with. Great customer service. Thanks Dan.
Here are a few pictures of the goodies I received yesterday.
Here is my 4 1/2 year old son Cole with the new composite spring.....man is that thing light Here is one of the NEW trailing arm assemblies!!!!! Here is a good view of the offset trailing arm
Dan just got my "stuff" from ups,,, It was worth the wait andy I'll send you pictures later this week, looks as though I will be busy this weekend bushog
Butch Malone
JPatrick,
I have the fiberglass dual mount rear spring and a regular fiberglass spring that will work with the double offsets. All I have to do is shorten them up 1" on each side. Running a double offset is going to give you the same tire clearance as a regular offset will. There is no advantage running the double except for the spring bolt hole is moved in 1". If you have no rear sway bar and run the offset or the double offset, you will be able to run a 10" wide rim. I don't have the exact tire size.
We would like to have your cores in within a month but if it's a little longer than thats OK as long as you let us know.
Rebuilt Offset trailing arms
Rebuilt Calipers
Trailing arm bolt/shim kit
Camber strut rod bolt kit
Front wheel bearings/seals
Front Rotors
Pinion Bushing
All new non-greasable U-Joints
