HELP with timing!! BAD NEWS
If so, have you disconnected the vacuum advance before setting the timing? (You may have to tweak up the idle to keep it running when you disconnect the vacuum advance)
It is also possible, if it's running, that the ring has slipped on the harmonic balancer and the mark on the balancer is no longer TDC.
Good luck!
Joe
OHH and i DID have the thing plugged with a golf tee
PS here is whats wrong with my car --> http://forums.corvetteforum.com/showthread.php?t=913615
Step #2: After getting the #1 piston to TDC look at the timing mark and make sure that the groove on the harmonic balancer lines up with the TDC on the timing marks. If it does not line up...and it's like 4" off like you say it is then you have sheared the key (small rectangular piece of metal which locks the inner groove of the harmonic balancer with the crank shaft) and will need to remove the harmonic balancer, clean up any messes it made, install a new key and re-install.
Step #3: If you got here then your timing marks are correct and there is no mechanical problem with your timing marks. Make sure your timing light is set to read TDC (some lights allow adjusting the light for advance). It is not possible for the timing to be 4" toward the passenger side cause that would be around 90º BTDC and the engine would not run.
You should get a repair manual and study it before tearing everything apart if you haven't done this kind of stuff before. An alternative is of course to take your vette to a mechanic.
Mike
Mike
I don't know about 78's but on my 72 sb, the #1 plug is tower just to the right of the center of the dwell window, standing at the front of the car looking towards the firewall. That is the center of the #1 spark plug tower is the right hand edge of the dwell window. When I had timing issues on my newly acquired 72 I took nothing for granted. I pulled all of my shielding off and physically checked and tagged each wire. Then I put the wires in the right place and re-did the timing. You can also buy the book "How to Rebuild Your SB Chevy", available at the NCRS store at www.ncrs.org, and it will walk you through the distributor, timing, and spark plug orientation issues. Well worth it, especially if you are an electrical moron like me.
Gary
just look at my picture above. That is a view of the distributor from above. The front of the car is labeled, and you can see the orientation of the wire pack on the HEI distributor.
so, find your number one tower, then go down to where the cap meets the body of the distributor. Draw a line on the distributor body right under the terminal of the #1 terminal. Then when you have the cap off and are installing the distributor you want the rotor to point to that line when you have the distributor fully seated in the engine and the engine is set to top dead center. Know that when you are installing the distributor the rotor will turn as it goes into the engine, so you need to set the rotor ahead a little. If you did it right, the rotor will line up with #1 when installed.
HEI distributor correctly installed in car, front of car on left, viewed from drivers side. Note #1 terminal.
Under the #1 terminal make a mark on the distributor body. See black mark on distributor body, under the #1 terminal.
Now remove the cap.
Start installing distributor body in engine. Note that rotor is not pointing at the mark for number 1 on the body, but is turned pointing more at the fender. That is because as the distributor drops into the engine and the gear engages the cam gear, the rotor will turn. The objective is to have the rotor point to the mark for #1 when the distributor is FULLY SEATED.
As such.
If the distributor will not full seat in the engine it is most likely because the oil pump shaft slot is not lining up with the notch at the end of the distributor shaft gear. You will have to take the distributor back out and with a very long flat screwdriver turn the oil pump shaft. You need to turn it so when the distributor drops in the engine fully it lines up with the inside of the distributor shaft gear. This takes some practice.
If all is seated well the rotor should be pointing very close to the #1 mark when fully seated. If you have the crank set at 0 degrees timing it should point right at it. If you want to set your static timing, turn the crank to about 8 degrees before top dead center and then turn the distributor body so the mark lines up with the rotor. You will then be able to secure the distributor, install the cap, wires and fire it up. Time with a timing light after that.
Hope this helps.
Just for fun, take a look at your dampener to make sure it isn't coming apart. The outer ring should be reasonably flush with the back of the pulley. If it is off by more than 1/4" you are on the way to disaster. More than 1/2" and you are on borrowed time already. Most just slip around and stay put, but you should check to make sure. Joe
If that has happened your mark will be off.
If you don't have too radical a cam.....
... get useself a vacuum gage and tee it into the system...with engine running at idle, adjust your points to get your highest vacuum. Then adjust your dist. timing for highest vacuum. You can also adjust your carb with this gage. You can look for a timing mark if you want but when engine is running its best it is pulling the most vacuum and the needle will be steady. An unsteady needle could be burnt valves, vac leak, loose timing chain or ?. If you can see your mark and it is drifting back and forth suspect bad timing chain.
