I put the intake in and it seems to fall into place, but will not seat against the intake manifold. There's about a 1/4"-3/8" gap between the intake and distributor bottom... doesn't seem to be anything above that's holding it in. I can feel it seat and the rotor shaft no longer spins.
Sure, did you remember that the dristributor drives the oil pump? If not, this is the answer and simple to fix. Just use a long screw driver to slightly rotate the oil pump untill the distributor can dropsin all the way, i.e, notch in the pump is lined up correctly with the end of the distributor shaft.
Steve - kind of like the other poster said. The dist. has hellical cut gears. So the shaft rotates down in.
So you put #1 cylinder on TDC and check your damper for "Zero" + or -10 degrees. Look under your dist gear and see where the slot resides with your rotor pointing to where #1 plug wire goes. Then take a long screw driver and turn the oil pump shaft into alignment.
When you stab the dist in start it about 360/8 = 45 degrees CCW and it will rotate on it's way down right in.
You wiggle the rotor to make it drop or even just bump the starter key and it will fall into place. Or if you have a 1/2 inch drive bar on the crank damper nut - Just move the crank back and forth and it will drop in.
First time starts every time Fire it up and if your timing is off 20 degrees your ONE tooth off and stab it again
From: San Diego - Deep Within The State of CONFUSION!
Leave the dist where it is and bump the starter, or crank the harmonic balancer bolt a bit, til it drops in.
That is the method I am now using, much easier than trying to get the oil pump lined up. Just be aware that the dist will rotate a few degress as it slides down in the the pump shaft so it may appear to be in line before you bump the starter but will actually rotate and be a tooth off.
Sounds a little scary to bump the starter not knowing for certain if the distributor gears are meshed. But likely you guys have much more experience with this than me.
Couple of thoughts: rather than a long screw driver, I actually use the tool for oil priming the engine and rotate the oil pump by hand until it will allign. This tool (sure there must be some proper name for it) works great, and helps to make a mark on it to determine how much the oil pump is being rotated.
If the rotor wasn't marked when removing the distributor, and you need to go back and line it up with #1 cylinder at TDC during compression stroke, old distributor caps work great. Just cut out a window under the #1 pole to visually locate when the the rotor is correctly positioned while hand rotating the engine.
If the dist drops to with a 1/4" of the intake then the gears have to be meshed but the pump shaft is not aligned, simple matter of physics unless the intake is too high or the dist is too short which is possible but not likely fif the intake was not changd and you are stabbing the same dist. Was a little leary of the method but decided to try it and it works fine, just make sure to unhook the coil.
No need to drill holes. Put the cap on and make a mark with a sharpie under the #1 tower centerline on the aluminum part of the distributor below the tower. Take tha cap off and drop it in.
If you bump it, you never know where it is going to drop down. Much better to turn the oil pump shaft with a screwdriver, priming tool, flattened pushrod or something. Then you know it is still at TDC and you know where the rotor should be pointing.
