Does this look correct?
Old Oct 1, 2004 | 07:57 AM
jacobsed's Avatar
jacobsed
Default Does this look correct?
I bought a used shifter mechanism from a vendor that will remain nameless . It looks like the shifter neck was welded back on. It doesn't look right to me and wanted somebody to verify one way or the other if it will be a problem.
http://home.comcast.net/~jacobsed/vette_001.jpg
http://home.comcast.net/~jacobsed/vette_002.jpg
http://home.comcast.net/~jacobsed/vette_003.jpg
http://home.comcast.net/~jacobsed/vette_004.jpg
Old Oct 1, 2004 | 08:10 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Jacob, your frame is looking good. You have taken on quite a project. I will run outside and check my shifter out, but it looks like yours is just like mine.
Old Oct 1, 2004 | 08:26 AM
comp's Avatar
comp
looks like iv'e seen
Eddie 70's Avatar
Eddie 70
I just came in from looking at mine and it is not welded, but it is at that same angle. I shot a few pics for you to look at.
http://temp.corvetteforum.net/c4/edd...er__small_.jpg
http://temp.corvetteforum.net/c4/edd..._2__small_.jpg
http://temp.corvetteforum.net/c4/edd..._1__small_.jpg
Hope this helps. If you need anymore pics, just let me know.
Old Oct 1, 2004 | 09:42 AM
jacobsed's Avatar
jacobsed
Thanks for the fast reply. Glad to see the same angle there. For some reason I thought it would be straight because of the assembly diagrams from the catalogs. The project is a 79 that I'm converting from an automatic to a manual I also have the 69 that is shown in my avatar.
I'll take more pics of the 79 project and post those later.
To Does this look correct?
