Build Sheet
Old Oct 1, 2004 | 09:52 AM
72LS5's Avatar
72LS5
Default Build Sheet
I'm a new member to the forum and to corvettes. I have a 72 coupe, LS-5, 4-speed, P/S, A/C. I've heard that the actual build sheet to the car may be on the top of the fuel tank.
Does the retreival process require you to drop the tank or can it be done without the tank being removed? If not, any advise on how it is done?
If so, what all is involved with removing the tank from the car?
Old Oct 1, 2004 | 10:05 AM
LemansBlue68's Avatar
LemansBlue68
You may be able to bend the lip of the rubber fuel boot down enough to peek at the top of the tank with a flashlight to see if it is there.
To remove the tank, remove the spare tire carrier, disconnect the fuel lines and sending unit from the tank, drain all the fuel and remove the cross member that supports it at the front. There are 4 bolts holding the cross member in place. Then you can roll the front of the tank down and out of the vehicle. Good luck on finding the build sheet!
Since you have a '72, the engine code is part of the VIN so there is no disputing whether or not you have an original big block car.
Old Oct 1, 2004 | 11:13 AM
72LS5's Avatar
72LS5
Sounds easy enough. My VIN has the W in it, so I know its an origninal BB car. What all information does the build sheet have on it? Will it tell me every option the car came with, including gear ratio?
Also for the corvette history guru's I have another question. Didn't GM have a huge strike in 72? Did it have any affects to production.
This forum is a great place to learn how to burn up all of your valuable time and money just to hear that V-8 talk to you. I will agree it is worth it.
Old Oct 1, 2004 | 11:56 AM
Missileman's Avatar
Missileman
To some, the build sheet is gold. But it is still a 32 year old piece of paper. If the build sheet is very important to you, take all precautions to remove it as a single piece, or not to cause eradication of the typed information. Most sheets tend to disintegrate when removing, especially through a one inch opening at the fuel filler. I recommend dropping the tank if preservation of the build sheet is your goal. It takes only a couple of hours to remove and you can properly access the sheet in terms of preservation (lightly brushing the dust off with a paintbrush, attaching laminating plastic to the top, gently removing the glued portions from the tank, etc.) Just like restoring a Rembrant.
Old Oct 1, 2004 | 12:20 PM
1971Coupe's Avatar
1971Coupe
on my 71, the build sheet is on the passenger side on top of the tank, I didn't remove it, but you can get at it by removing the spare tire tub only.
Old Oct 1, 2004 | 01:19 PM
stingray4me's Avatar
stingray4me
I couldn't see anything from the fuel filter area. When I removed the tank (75) all mine had was the paper of where it was delivered to.
Old Oct 1, 2004 | 05:17 PM
hunt4cleanair's Avatar
hunt4cleanair
Yes! If you look in a black book and see the options available...the tank sticker which is actually a copy of the Corvette Order, will list what options were ordered including the base model ordered. The base model is either the coupe or convertible. It will list tilt/telescopic steering column, alarm, interior if deluxe, tires, tranny, motor, paint, axle ratio, positraction (in 72), seat belts, radio, etc.
Hope this helps.
Old Oct 1, 2004 | 08:01 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
did they also put the build sheet on the tank in 76. just asking cause this is the first i have ever heard of this and if so this is gonna be really good news to me sense i just got my new stainless steel gas tank today that i was planning on putting in this weekend and now i know what to look forward to. im so excited i want to go out right now and pull the old tank. cant wait to get my new one in with its internal electric pump so i can start setting up my EFI. ohhhhh im so excited now
Old Oct 2, 2004 | 12:23 PM
72LS5's Avatar
72LS5
Thanks guys for all the advice. Ir it is there I hope to retrieve it in one piece.
Old Oct 3, 2004 | 01:42 PM
GaryS's Avatar
GaryS
there has been more than one report of someone trying to remove a build sheet without dropping the tank and winding up bit shreds of paper. Dropping the tank isn't that difficult if you really want to get a good shot of removing your build sheet without tearing it. Take a good flashlight and peek between the left side of your rubber gas boot. If you can see something up there, then I would take the few hours of work and drop the tank.
Gary
To Build Sheet
