Motor mount question ?
Old Oct 1, 2004 | 09:56 AM
1970-Bronze's Avatar
1970-Bronze
Default Motor mount question ?
Ok, I pulled the engine in the 70' and the stock motor mounts were in two pieces - so I ordered new urethane ones.
The urethane ones showed up today in two pieces...???
Are they suppose to be? Can someone shed some light on this?
Old Oct 1, 2004 | 10:21 AM
GTR1999's Avatar
GTR1999
Stock rubber mounts should be on piece with a build in safety.If they rip then they come out as 2 pieces.
The poly ones are solid with the safety molded inside the mount with a steel plate, is this what you're referring to?
Gary
Old Oct 1, 2004 | 10:26 AM
Fevre's Avatar
Fevre
That is normal, it mentions it in the directions. Happen to read them?
Old Oct 1, 2004 | 10:32 AM
1970-Bronze
Well, the stock one definitely is in two pieces so that wasn't good. They did lock together but it almost looked correct.
Well, I don't understand why there's the extra plate with the urethane mount..... It looks like you could install it without the plate.
The instructions really doesn't explain it or why it's a two piece design.
Oh - it's the Energy suspension 3-114G part number.
Old Oct 1, 2004 | 10:37 AM
JJ Deuce's Avatar
JJ Deuce
I got the Energy Suspension mounts as well. The extra plate is listed in the instructions as a "preload plate." There's one for my tranny mount also.
Old Oct 1, 2004 | 10:43 AM
1970-Bronze
Yes, it is..... I think I understand now.
Thanks for the help....
Old Oct 1, 2004 | 11:19 AM
Fevre's Avatar
Fevre
I generally don't read instructions but I just happen to on this one or I would have left the plate out.
To Motor mount question ?
