Finally, New Engine Installed In '75 Coupe...
Old Oct 1, 2004 | 11:15 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Finally, New Engine Installed In '75 Coupe...
Installation went very well. Picked motor off the stand, installed flywheel, clutch & pressure plate, bellhousing and transmission. Hoisted eng/trans high enough to clear front nose, gently "rolled" car forward with hands on the tires, lowered eng/trans as I brought the car forward and within an hour motor/trans were in place. Hooked up fuel lines, clutch "Z" bar, clutch pedal linkages, brake vacuum lines & such, throttle cable. Waiting on my rebuilt water pump from Gould's in NY. Still have to pull automatic shifter & console plate, install new Hurst Competition Plus shifter & rods & new 4spd console plate, starter, driveshaft, radiator & core support and distributor. At least now I'm getting real close-hope to be driving it MAYBE next week.
Old Oct 1, 2004 | 01:42 PM
NHvette's Avatar
NHvette
So, maybe I missed it.
Your sig says it's an auto ... did you do a 4sp conversion, also ?
Sounds like you had a very rewarding day. Hope the rest of it goes smoothly.
Old Oct 2, 2004 | 03:31 PM
Paul Borowski
Thanks-I missed that-yeah, I'll have to change that too
Old Oct 2, 2004 | 04:09 PM
ICEMAN59's Avatar
ICEMAN59
man I'm envious 4 vettes too cool
Old Oct 2, 2004 | 04:45 PM
Paul Borowski
Had "5" for about 4 months last year-garage was'nt BIG enough.
To Finally, New Engine Installed In '75 Coupe...
