Decided I want flame throwers
Old Oct 2, 2004 | 12:20 AM
munday's Avatar
munday
Default Decided I want flame throwers
The show pimp my ride is stupid, at least to me. It falls right in with every other MTV show, but they put flame throwers on an exhaust. I'm thinking I want this now.
Anyone got some good Ideas on how to do it? I don't have sidepoops err pipes.
Old Oct 2, 2004 | 12:50 AM
1979toy's Avatar
1979toy
Check with these companies.
http://www.gotflames.net/hypercart/catalog.asp
http://www.hotrodsetc.net/menu.html
Don't forget that the plastic on the rear of your car is NOT going to like all of that heat.
Old Oct 2, 2004 | 11:31 AM
brystheguy's Avatar
brystheguy
http://www.phreakco.com/punksg/diy/flame.htm
I'm not sure how well it would work but it's cheap enough to try it out.
Old Oct 2, 2004 | 11:52 AM
stingry's Avatar
stingry
St. Jude Donor '05-'06
This won't work. Just switching 12V dc to a spark plug will do zip! The "gotflames website FAQ" also warns against this. A normal ignition pumps up the voltage,hence you get the "jump" across the spark plug junction which is the spark. You essentially need a simple ignition system for the spark plugs in your "flame thrower". A simple device to do this may be something like a cheap electric fence system. It pulses a high voltage at regular intervals. Just want you would want for flames. I haven't tried it but it sounds like a cheap, simple alternative.
Old Oct 2, 2004 | 11:58 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
you could use just a switch and an ignition coil.
Flip the switch on and off and you'll get a spark...
Old Oct 2, 2004 | 09:12 PM
74FLCONV's Avatar
74FLCONV
How about rigging up an electronic starter from a BBQ grille? That device is compact and seems to make a healthy spark.
D. Ocean
Miami, FLA
Old Oct 2, 2004 | 09:38 PM
carhound's Avatar
carhound
I've seen the flame throwers in movies but never in person. What causes the hugh flames, propane????
71coupe's Avatar
71coupe
Think it would work with the mufflers that close to the tips? I would be concerned with the mufflers holding too much vapor & not going out after it's lit. Kinda pimp-rice too.
Old Oct 2, 2004 | 09:49 PM
munday's Avatar
munday
yeah but next time caravan dad or suburban mom pulls up to close at the stop light.....WOOOOOOF, there goes the paint and I'm off.
Old Oct 2, 2004 | 10:00 PM
71coupe's Avatar
71coupe
Good thinking
Old Oct 2, 2004 | 10:55 PM
Corey_68's Avatar
Corey_68
No, no other fuel besides gasoline. External coil, spark plug, wire, toggle switch and a rich carb is all you need.
Old Oct 2, 2004 | 11:42 PM
munday's Avatar
munday
don't want to run a rich carb, gas acts as a solvent and washes the oil off the cylinder walls.
Old Oct 2, 2004 | 11:45 PM
Corey_68's Avatar
Corey_68
True, but at a car show you'll see the guys with the 50 Mercs and other lead sleads richen up the mixure to produce the larger flame. Richen it up for the show, lean it out on the way home. It's illegal to use on the street anyway.
Old Oct 2, 2004 | 11:50 PM
munday's Avatar
munday
I think I just need a twin turbo 4litre that shoots them when downshifting.
Old Oct 2, 2004 | 11:58 PM
comp's Avatar
comp
To Decided I want flame throwers
