Do big blocks run hot?
Old Oct 4, 2004 | 11:58 AM
cruiser69's Avatar
cruiser69
7th Gear
Default Do big blocks run hot?
i have a 69 427 where my feet get pretty warm on hot days, is it true that big block engines run hot and by "sitting" on the engine it is hard to keep the heat away from your feet?
Old Oct 4, 2004 | 12:16 PM
Corey_68's Avatar
Corey_68
If it's running hot then you have a problem somewhere. I'd evaluate the thermostat making sure it's opening, then I'd check the radiator. Normally if the water pump is going out it will leak and/or make noise. A fully fucntioning coolant system will properly cool a BB.
Old Oct 4, 2004 | 12:20 PM
cruiser69's Avatar
cruiser69
7th Gear
Sorry, I didn't explain very well. What i meant was the heat that comes off off the engine makes the interior very warm. The engine temp is fine i just cant keep the interior cool enough on a hot day
Old Oct 4, 2004 | 12:40 PM
Corey_68's Avatar
Corey_68
Then yes, the heat from the floorboard is normal. This is why many guys switchto side exhaust, it eliminates the problem. I believe some herr have wrapped their exhaust/headers to reduce the heat.
Old Oct 4, 2004 | 12:56 PM
cruiser69's Avatar
cruiser69
7th Gear
thanks, you settled a bet for me!
Old Oct 4, 2004 | 12:59 PM
PRNDL's Avatar
PRNDL
there is a whole series of steps to take which can significantly improve your in-cabin comfort. The steps are documented several places, including the "weekend projects" book. Off the top of my (flat) head, I checked the firewall for holes (usually missing grommets) that allow heat into cabin. Install a heaterhose cutoff valve so hot air is not circulating thru your heatercore during the summer. This would give you hot air out the vents even if the heater and fan are turned off. Check the shifter boot (if 4spd) for tears and replace. There is an inner rubber boot underneat the outside one. Check underneath for addition or possible replacement of foam collar around trans and aluminum foil backed heat shield around trans. You could install heat shields between the exhaust pipes and the floor. I put in insulation (heat shield type stuff) up against the firewall. Finally you might want to rip out all of your carpet and install foil backed insulation underneath your new carpet.
Old Oct 4, 2004 | 01:03 PM
PRNDL's Avatar
PRNDL
what bet was that? You are driving a 35 year old car. It is very common with cosmetic restorations that make the car look very nice but leave out invisible items like under-car heat shields or even undercarpet insulation. You will have to survey original owners to find out how hot they were inside when new.
Old Oct 4, 2004 | 01:12 PM
Corey_68's Avatar
Corey_68
If you think the Vette's floorboard is hot don't EVER drive a Viper longer than 20 minutes.
Old Oct 4, 2004 | 03:42 PM
1Bad69's Avatar
1Bad69
Did not help my foot heater any..still plenty warm....
Old Oct 4, 2004 | 04:17 PM
Larry B.'s Avatar
Larry B.
All of my seals and insulation are in place. the heater?AC doors work fine and heat is not a problem in my BB69 even with the A/C on.
Old Oct 4, 2004 | 06:13 PM
70_Shark's Avatar
70_Shark
I have insulation and the heatshields and it gets warm with the headers.
I did not know that Vipers heat up. I've never been in one.
One more note, I saw a C6 Sunday and at first glance I thought it was a Viper.
-Dan
Old Oct 4, 2004 | 06:17 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Not when their being towed by a small block.
Old Oct 4, 2004 | 06:40 PM
JB's Avatar
JB
St. Jude Contributor
Given Larry's experience & mine, it's my guess that the tunnel insulation is the really important part. My original insulation is all there, down to the metal sheilds under the floorpans EXCEPT that someone in the past carefully cut the section that lines the tranny tunnel out. And my feet get PLENTY hot, though it takes a while for the heat to build up.
JB
Old Oct 4, 2004 | 06:45 PM
Corey_68's Avatar
Corey_68
I didn't know small blocks make enough torque to tow anything.
Old Oct 4, 2004 | 06:46 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old Oct 4, 2004 | 09:32 PM
norvalwilhelm's Avatar
norvalwilhelm
I believe in header wrap. My headers have been wrapped for over 10 years without a problem. There is no problem with hot floors and when you lift the hood after hard driving there is no wave of heat that strikes you.
Old Oct 4, 2004 | 10:07 PM
Cali,68,L-79
350ci
I'll explain the theory of gearing when you graduate high school.
Old Oct 4, 2004 | 10:41 PM
Corey_68's Avatar
Corey_68
350ci
Hey now...
Old Oct 4, 2004 | 11:09 PM
Cali,68,L-79
To Do big blocks run hot?
