2 post lifts
http://www.completehydraulic.com/cl7000bpa.htm
They sell them on ebay too. Chances are they are most likely not built in the U.S., but for a home shop, what do you guys think?
Joe
Pay no attention to the German or Japanese cars in this picture.
cryzko
detroit
Here's a link to their website:
http://www.stingerlifts.com/
Also, the illustrated lift has a bar that runs along the floor. This will become a source of nuisance as you stumble over it, spill you dirty oil, can't wheel your creeper/tool box over it, etc. The better way to go is with a "clear floor" design that routes the crossover overhead. This then requires over 12 feet of headroom.
A few months ago I purchased a lift and it is one of my favorite tools. I should have gotten one sooner!
Initially I wanted an asymetric 2-post lift but when I called to inquire about them I was told that I needed to have at least 5-1/2" reinforced concrete where the lift would be mounted. My concrete slab wasn't up to the task so I opted for the M-80 4-post lift from AutoLifters out of Kansas. http://autolifters.com/m80.html
A mechanic friend of mine has both a 2-post and a 4-post in his shop and he said that he uses the 4-post 80% of the time. I'm sure that each has it's advantage.
My 4-post lift can be moved. This summer I left it outside, under the carport which allows me to take advantage of the cool breeze and natural lighting. Washing/detailing my cars, trucks, and motorcycles while on the lift is easier on the back since you don't have to bend over to clean the tires/rims, etc.
This winter I will move the lift forward, into my shop. Once you raise the lift to it's highest point, the floor space in that area is only obstructed by the four legs.
You can raise the tires off of the ramps by using a jacking tray that fits between the ramps or use a small floor jack under the edge of the car frame.
With a 4-post lift, turn-plates, and appropriate alignment tools you can fiddle with your alignment settings.
As mentioned earlier, it can be used to lift a motorcycle. I have 24" wide ramps so either the kick-stand or center-stand works well to stabilize the bikes.
I've even used it to lift my riding mower so I could pressure wash under the deck and remove/sharpen the blades.
It's also very handy for use as a temporary work bench. At the end of a good weekend wrench-athon we pull up the bar-stools, break out the beer and it serves as an excellent make-shift bar!!!
We've got 3 4 post lifts. 2 of them with secondary jacks to lift the axles. Also have 3 2 post lifts I like the four posts with jacks alot more than the two post. If you do get a two post, go asymetrical otherwise you will have to be very careful not to dent, ,scratch, or crack doors. A car with little ground clearence will have trouble getting on to some four post lifts.
