Need Carb suggestions for 406ci engine
I talked with Mark at AR Racing and he recommended a 750 cfm Demon with vacuum secondary.
However, the guy who is putting the engine in recommended a 750 Demon with mechanical secondary.
Can you guys give me suggestions as to what carb I should run, either between these two or any other carb out there?
Also, I had an Edlebrock carb on an old mustang of mine. Whenever I would take a corner fast it would die. I believe it is because it was based on an old design and the fuel would splash around in there and the engine would starve. Do Demons and/or Hollys have this problem?
Thanks!
Thanks!
800-850 HOLLEY.
Mechanical secondaries (manual or auto) for a car that goes to the track. Vacuum secondaries (manual or auto) for a car that spends all its time in the street.
I was looking at a speed demon at jegs, and saw it was rated for like 427ci or bigger engines. Their 750 was rated to cover engine sizes well over 406ci.
Why are all yall going the 800-850 route? If 750 will flow enough air to cover the engine needs, won't an 800/850 give a little worse throttle response?
Thanks again.
Carbs are rated at 1.5 hg.
The vacum at 6200 rpm will be 1.5 -2.0 hg with a 750 carb. A 850 carb will have less restriction , giving 1.0 -1.5 hg resulting in a power increase of 25-35 HP on a 406 . Anytime you can decrease engine vacum at wide open throttle , you will increase power.
The mistake alot of people make is to over carb a base engine like a L-48 ;that the carb is not the restriction; the intake and heads are the problem.
Thanks again.
AR may have tested different carbs and perhaps that is why they are recommending a 750 vacuum secondary carb.
Have magazines ever run tests and compared the two on a 406 engine to conclude that you get more HP up top?
Oh yeah, why do some of you guys suggest Holly over Demon? Any problems with Demons?
Also, can anyone comment on whether Holly/Demon carbs will cause the car to stall in a tight turn do to fuel distribution problems like an Edlebrock carb will?
Thanks.
Lemme ask yall this: Do stock quadrajets come with mechanical or vacuum secondaries?
Thanks.
