Cardone Calipers
Old Oct 5, 2004 | 04:34 PM
koni9's Avatar
koni9
Default Cardone Calipers
Are these calipers any good?
Some feedback would be great.
Old Oct 5, 2004 | 04:59 PM
R. Bruno's Avatar
R. Bruno
I haven't used their calipers, but I have gotten other rebuilt stuff from Kragen (power steering pump, alternator). It is strictly low end, and if you buy 4 calipers, I will bet that you end up exchanging 2 immediately. Sure, they have a lifetime warranty, but you don't want to do that job twice. Call Vette Brakes and get an o-ring set. Forget Cardone - thiat stuff is good for an old car you do not plan on keeping.
Old Oct 5, 2004 | 05:36 PM
72LS1Vette's Avatar
72LS1Vette
I've had varying results with Cardone rebuilds. A rear caliper (Mazda) leaked after 3 months. A rear cylinder (F**d) leaked right out of the box. A F**d master cylinder was OK. Good thing they have a long warranty.
I think you take your chances with any rebuilt item.
Rick B.
Old Oct 5, 2004 | 07:58 PM
MN-Brent's Avatar
MN-Brent
My rebuilt power booster is Cardone.
For the brake calipers, get the Cardones and get the VBP conversion kit for O-ring pistons.
The Cardones will be stainless steel sleeved. Remove the OEM lip seal pistons and install the O-ringers. Anything less and youll probably be doing it again soon. Winter storage allow the OEM seals to develop a memory and they then have a tendency to start leaking in the spring when you start moving them again.
Brent...
Old Oct 5, 2004 | 08:34 PM
81 Vette's Avatar
81 Vette
St. Jude Donor '05
First C3 General Poster!
Personally Id go with SSBC Force 10 Extreme 4-piston aluminum calipers with 43mm pistons. 2x 2 wheel kit. SSBC 12” sport slotted rotors, 4 wheel kit. OR VBP Corvette Sport Brake Upgrade 4 wheel kit.
Well worth it if you ever plan on putting some power in the Vette.
Old Oct 6, 2004 | 08:41 AM
stingr69's Avatar
stingr69
Bought calipers and M/C from Autozone. Good price but watch out! The drivers side front leaked, the first replacement leaked as well AND had been welded/ground and was not paralell from one half to the other!
The third one was a charm though. If you have the time and not the money, go for it.
Here is a tip - Keep your cores untill you KNOW for certain the job is done right. I gave mine to them and had no option to return the parts later and buy better ones. The cores are GONE.
-Mark.
To Cardone Calipers
