Heater Core Box Removal One ????
Old Oct 5, 2004 | 05:40 PM
Karfever's Avatar
Karfever
Default Heater Core Box Removal One ????
Yes, I am in the PITA of all jobs, heater core replacement. Why would I do this in Florida? Anyway, can one of you tell me where to access the nut on the stud for the upper left corner? I cant find it under the hood, and I imagine that is where it is??
Old Oct 5, 2004 | 05:41 PM
Karfever's Avatar
Karfever
The stud is for the heater box, or air distribution box is the correct term, which is inside the passenger side. Yes it is a factory AC car, 1969.
Old Oct 5, 2004 | 06:42 PM
Rod Russell's Avatar
Rod Russell
7th Gear
I just did this and I remember it wasn't where I thought it should be. Do you have an assembly manual?
Old Oct 5, 2004 | 06:57 PM
redwingvette's Avatar
redwingvette
I haven't taken on that job YET, But here is a web page for a 70. Hope it helpsHeater core
Old Oct 5, 2004 | 07:28 PM
Karfever's Avatar
Karfever
Thanks for the link redwing, but I have that all ready. It just doesnt help me locat the nut for that upper left stud, which I believe should be in the engine compartment. If it is in the A/C box them I am srewed!
HELP!!!!!!!
Old Oct 6, 2004 | 07:07 AM
Karfever's Avatar
Karfever
ttt
Old Oct 6, 2004 | 07:54 AM
Karfever's Avatar
Karfever
Oh boy, It just goes from bad to worse. I found the nut on the firewall neat the ac box, but now the +&*%##@# upper right bolt holding the box on is stripped, or probably the cage nut or whatever secures the bolt has broken.
Doe anyone have a idea what to do now? I dont think I can drill the bolt head, beacuse of the location. I dont want to resort to a bubba fix unless it is the last resort, HOWEVER, there is no way at this point that I am going to give up! I WILL replace that D*mn heator core!
Old Oct 6, 2004 | 09:39 AM
carnut114's Avatar
carnut114
When i did my 72 454 with a/c I had a big rivet in the top center holding the box on. I took the bolts off of the corners then i had to drill out the rivet with a 12" drill bit. When i put it back together the corner bolts held it on fine. I hear they put this rivet on at the factory during assembly.
Eric
Old Oct 6, 2004 | 10:07 AM
1970-Bronze's Avatar
1970-Bronze
Can you get in there with a dremmel and cut it off?
I'm going to have to do this later this year. Are you taking any pics?
Old Oct 6, 2004 | 11:17 AM
Karfever's Avatar
Karfever
I dont know if a dremel will reach or not. I will take some photos tonite.
To Heater Core Box Removal One ????
