Dropping the distributor in for the first time?
Old Oct 6, 2004 | 02:04 PM
ImBatman's Avatar
ImBatman
Default Dropping the distributor in for the first time?
I am not close to doing this yet but would like some clarification on the best proccess to guarantee that the distributor is installed right the first time. I have the cam in and lined the dots up with the cam sproket dot to the bottom and the crank sprocket dot to the top. I think I read in a post a while back that you should then rotate the engine until the cam dot is at the 12 o'clock position and the crank dot is at 6 o'clock. Then drop the distributor in with the rotor pointing towards the #1 cylinder. Is this correct?
Old Oct 6, 2004 | 02:18 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Just get #1 to TDC on the compression stroke, and aim the dist rotor at the right place in the cap to hit #1. If the oil pump shaft is not lined up right, the dist will sit up, off the gasket 1/4 inch. In that event, rotate the motor clockwise a tug or two, until the dist drops into place.
Old Oct 6, 2004 | 03:02 PM
SG4206's Avatar
SG4206
In answer to your question ,Blackrat you are correct.
Old Oct 6, 2004 | 03:04 PM
Garys 68's Avatar
Garys 68
Find TDC, using the timing mark. On the compression stroke, just put your finger over the spark plug hole and you'll feel the air come out while cranking.
The distributor will turn about 1/4 turn when you put it in. It may take a couple trys to get the right mesh for the correct position.
The oil pump shaft alignment can be adjusted with a long screwdriver. That may take a couple trys too.
Gary
Old Oct 6, 2004 | 03:18 PM
ImBatman's Avatar
ImBatman
Thanks guys. I want to get the marks as close to dead on as possible so I was planning on putting the timing cover on last. I don't have heads on my engine yet. This before I do it question.
Old Oct 6, 2004 | 04:11 PM
Fevre's Avatar
Fevre
Prolly want the timing cover on before you prime the eng, , dist is usually the last think that I put on before I fire it up!
Old Oct 6, 2004 | 06:22 PM
72GACRZR's Avatar
72GACRZR
Here's a how to from the tech tip section
https://www.corvetteforum.com/techti...=275&TopicID=5
Old Oct 6, 2004 | 08:08 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Finding TDC #1 with the heads off should be real easy . If the lobes of #1 are pointing down, you're on the compression stroke where you want to be. If not, rotate the engine 360º. When the timing cover and tab are on, rotate the engine back until the marks align at the proper initial advance setting, not at 0º. When you drop the distributor back in make sure that it is properly oriented and with the rotor pointing to the #1 postion of the cap.
Old Oct 6, 2004 | 11:48 PM
Rockn-Roll's Avatar
Rockn-Roll
I keep the crank at the TDC mark and use a long screw-driver or the oil pump primer tool to turn the oil pump shaft so that the distributor lines up. This way it's easier to set the initial timing by inspecting where the rotor is in relation to the cap. I usually just set the timing to 0º cause it won't hurt to be around there within 10º , while trying to get it set at the 10º or so BTDC may be too far advanced by 10º and thus cause a 20º BTDC idle timing which may cause some backfire through the carb due to the addition of other factors including the lash not being adjusted on the rocker arms yet. Which reminds me...I usually set zero lash for initially starting the engine...it makes sure that all the valves are going to close and eliminates another chance that the engine will backfire.
Old Oct 7, 2004 | 03:44 AM
GaryS's Avatar
GaryS
Spend a few bucks and buy "How To Rebuild Your Small Block Chevy". They give a nicely detailed description of how to do this right every time. Measurements, techniques, etc. It made it easy enough that I did it right. Some of the advice given here is almost right and can cause profound headaches while you try to troubleshoot why your car runs like a POS after the distributor install. Go to www.ncrs.org and click on the store logo. Buy the book there. You will be happy you did.
Gary
Old Oct 7, 2004 | 11:24 AM
norvalwilhelm's Avatar
norvalwilhelm
I have done this many times. With the drivers valve cover off I rotote the engine watching the number 1 valves, I watch for the intake to open, then close and I continue turning past the intake closing until I come to TDC.
I have the distributor marked which plug I use for #1 and mark the distributor body so I know where it is.
I then drop the distributor in so that the rotor points to this marking on the housing.
To Dropping the distributor in for the first time?
