bb crank P/N
Old Oct 8, 2004 | 03:16 PM
WESCH's Avatar
WESCH
Default bb crank P/N
Hello
My 68 BB got rebuild about 14 Years ago and has since than only done about 15.000 Miles.
The block was bored .030 over and a complete guts kit ( krank, rods, pistons ) got installed from TRW.
Forget 11.5 compression pistons, rods ?? and cast crank.
The kit was purchased without any extra balancing surplus.
I like to get all balanced and since I have to remove all, I like to change the crank against a forged one.
In E-bay, they offer a GM forged, nitrited crank , P/N 3856223, stroke 3.76.
Is this the original 427/435 HP L71/L89/L88 crank ?
They ask 240 $ for a new crank , is that OK.
Is this crank the crossdrilled one ?
What exactly do I need to remove for balancing ? Crank, rods, pistons and ???
I like to rev this engine to 6.500 , will the rods be OK from this kit ?
It was a L71 engine, but the previous owner rebuild the motor due to a twisted crank. He just bought the complete kit and threw all original stuff away, including the rods and pistons.
Thanks. Gunther
Old Oct 8, 2004 | 03:36 PM
Patrick73's Avatar
Patrick73
Gunther: That part number does not show up in my GM Chev. Corvette Parts Catalog. Group O.646 contains all the Corvette crankshafts.
The 427 crankshafts--depending on which engine--are listed as follows:
3882842, for year 66-69, special H.Perf 427
3882849, for year 1969, except Al. cyl and case special H. Perf
3967811, for years 68-69, with H.D.427
3879621m for 1967, with H.D. 427
Old Oct 8, 2004 | 05:46 PM
Brettmc's Avatar
Brettmc
Aren't those the truck cranks that weigh a ton??
Brett
Old Oct 9, 2004 | 02:36 AM
WESCH's Avatar
WESCH
Brett
Thanks so far.
Brett, why should they be more heavy ? The counterweights should only counterweigh rods n pistons ?
OK, truck pistons are slightly heavier due to the 3rd ring setup, but is this a lot ?
Rgds. Gunther
Old Oct 9, 2004 | 03:49 AM
BB wowbagger's Avatar
BB wowbagger
I think the L88 crank has #7113 as a casting number?
Old Oct 9, 2004 | 01:14 PM
WESCH's Avatar
WESCH
Hi again.
So, which still available forged steel hi-perf crossdrilled crankshaft is still available on today's market ?
Who offers something that is Vette specific ?
Thanks. Gunther
Old Oct 9, 2004 | 01:21 PM
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by WESCH
Hi again.
Thanks. Gunther
It is simple to cross drill any crank if you insist on a cross drilled one but it is not recommended.That said I cross drilled mine believing it would give better oiling.
Old Oct 10, 2004 | 04:18 AM
WESCH's Avatar
WESCH
Hi
OK, any suggestions about a good high torque hi performance steel crank for my 427 CI. Like I mentioned, I like to go to 6500 RPM max.
May be SUMMIT or ???
Rgds. Gunther
Old Oct 11, 2004 | 05:28 PM
WESCH's Avatar
WESCH
Hi
OK , here an advertisement :
These are right from GM, these have the GM part #3856223 right on the crank,
And I found this casting 6223 existing in the " How to rebuild BIG-BLOCK CHEVY ENGINES " book from Tom Wilson.
His listing is for 366 , 396 & 427 Engines.
So, it is a GM crank for only 240 US$, but is it useable in a short block Vette engine ?
It is suppost to be nitrided ( normally only done to high performance cranks ), but don't know if it's crossdrilled ?
Rgds. Gunther
Old Oct 12, 2004 | 12:43 AM
71coupe's Avatar
71coupe
That # is a 396 crank, it should work for a 427 (I think it's a little lighter than the 427). Maybe someone here can give you more info.
Old Oct 12, 2004 | 03:27 AM
WESCH's Avatar
WESCH
Hi
Yes, I also got a bit more info.
This crank was for example used in a 400 Chevelle 300 HP setup.
Now I know that 300 HP are not 435 HP used on Vettes, but this crank is also nitrited and crossdrilled, so ????
Damn, I don't know anything about cranks !!
Rgds. Gunther
To bb crank P/N
