Van Steel Delivers!
Arty and Danny described the repairs made and provided an excellent critique of the vette's road manners both before and after the repairs.
The 'fixes':
Replaced lower left front control arm bushings (rubber)
Tightened loose power steering hose (slow leak)
Replaced both rear trailing arm bushing kits
4-wheel alignment (performed by one of their trusted businesses)
Fixed problem with loose parking brake that resulted after install of custom x-member (Bow-Tie Overdrives 700R4 kit)
Arty described that Bow-Tie had not correctly welded the parking brake pulley onto the x-member; it was incorrectly positioned. I had advised Bow-Tie of my suspicions and even sent them a digital pic back in 20023 to no avail. Arty made it right and now I gotta remember to disengage the parking brake as I have driven without it since installing the new trans in 2002!
Arty also described a 'light steering' condition. The C3 rides higher than normal and Arty suspects the front coil springs were replaced at some point with the wrong springs. Front end ride height is about 29". Normal is about 3" lower... Also the tires are cupped and that says new shocks are due (very likely). We talked about the Bilsteins and KYB's and settled on a future install of KYBs, Van Steel coil springs and new alignment (along with fresh set of tires). Gonna be a while before I can drop the dough for that repair but have added it to my wish list.
Perhaps next job bonus can pay for those repairs. In meantime, I'm enjoying a much more stable and safe ride.
Thanks Van Steel!!!
glad the move went ok, sounds like your car is getting squared away to. I am about to install the crossmember that you referenced can you advise where the parking brake pully was incorrectly welded and exactly what they did to fix it? I suppose they cut it off with a grinding wheel and then rewelded it to the correct location. I just wonder if i will encounter the same issue, but now that i am aware you had a problem i will keep an eye on the issue.... although a little disappointed in the unresponsiveness BTO had to your issue. any help you can provide on this or that previous picture you took would be appreciated. thks bob
No better place to take a vette, IMO.
-Steve
NOTE: I purchased the Bow-Tie trans when there was just one level of trans available (I think the 400+ hp version). I believe they now offer about four different trans packages/levels and suspect quality is much improved in all parts and packages.
