Long painful couple of months. My stock shifter cable on my 81 auto snapped. Replaced with a napa unit, 2 weeks later, the shaft at the top crumples, replace with anouther napa unit, and 4 weeks later (today) it crumples as well.
Before I go through this ordeal again, is there an after market shifter that will bolt to the stock location without having to cut or drill anything?
I like some of the B&M auto shifters, but I dont want to hack up the floor to make them fit.
I see that they have console shifters for the same year Camaro and T/A. Will one of these work?
Could the problem lie elsewhere...such as is the shifting mechanism in the transmission binding somehow? You may be looking at the symptom and not the cause.
