vacuum line question
Old Oct 13, 2004 | 09:18 PM
logansrun73's Avatar
logansrun73
St. Jude Donor '14
Default vacuum line question
Does any one know where I can get a picture of the vacuum lines set up properly. I have a L-48 engine with the smog pump hooked up. There is one hard line out of the carburator with no line hooked to it. And one 3 way T missing a line also. I am having a hard time finding the proper set up. My service manual has no pictures. Thanks
Old Oct 13, 2004 | 09:45 PM
kdf1986's Avatar
kdf1986
Default Me Too!
Hello,
While our friends are at it researching, I have the same problem with a 1973 454 engine. I have some extra lines I dont know where they go, and the Chiltons guide and other parts books do not give me a good idea of the proper connections. So if anyone knows where I can find the correct carb connections and vacuum connections let me know where I can see this.
Thanks for letting me tag along with your earlier post.
kdf 1973 454
kdf 1986 L98
Old Oct 13, 2004 | 10:42 PM
logansrun73
St. Jude Donor '14
No problem!!!!! Hope someone can give us an an answer
Old Oct 13, 2004 | 10:47 PM
cw823's Avatar
cw823
Can you take a picture? Hard to visualize what you're talking about here
Old Oct 13, 2004 | 10:53 PM
logansrun73
St. Jude Donor '14
I,ll take a picture I,ll try to upload it never did it yet so it may take a while.
Old Oct 13, 2004 | 11:03 PM
bigvette1's Avatar
bigvette1
A couple of sources are
1. Dr. Rebuild catalog has a section of most engines with vacuum line connections.
2. Tom's 73 site has some info. Look at: http://1973-corvette.com/
3. Run a search on the forum for 73 vacuum lines and there is some info.
Good luck.
Old Oct 13, 2004 | 11:06 PM
4ME+N73's Avatar
4ME+N73
I Will Do This From Memory - Hope It Will Help.
Looking At The Carb From The Front. Small Line Lower Right To Fuel Vapor Canister. Large Lower Left To Pcv Valve. Small Line Lower Left To Solenoid On A.i.r. System. Line From Solenoid To Vac Advance On Dist. Small T Upper Left - One To Vac Choke Pull Off The Other To Egr Valve.
Old Oct 13, 2004 | 11:47 PM
logansrun73
St. Jude Donor '14
The administrator wont let me send attachments so i guess i can't upload the pics I would put it as my avitar but it would be blurry
Old Oct 14, 2004 | 07:56 AM
cw823's Avatar
cw823
Sign up at www.photobucket.com and then post urls. It's easy (I've done it)
Old Oct 14, 2004 | 08:02 AM
stingr69's Avatar
stingr69
Factory assembly manual has vacuum hose routing diagrams. I would advise anyone that is working on an old Vette to get one ASAP. They do not cost that much and they can be a major help when working on these old girls.
-Mark.
Old Oct 15, 2004 | 11:23 PM
logansrun73
St. Jude Donor '14
They are not accepting free accounts at this time Also is it hard to remove all that smog stuff including the air pipes that go into the manifolds?
To vacuum line question
