The front spindles look the same for all intents and purposes except that on has "13A" and the other has "13B" on it. Is there a right one and a left one or are they interchangeable? If not, which'n is it?
Thanks.
The steering knuckle goes towards the rear of the car and the brake mount goes towards the front.
The spindles are the same. The knuckles are different.
Thanks. They looked identical except for that stamp. I just wanted to verify.
I took the spindle, knuckles and brake mounts apart. The mounts and knuckles are clearly marked with a LH or RH or L or H so they weren't the problem. I just got concerned that the spindles themselves had some minute difference that I wasn't seeing.
Thanks again. Now it's time to get back to re-assembling my car.
