73 L48 Vs L82
The testers really liked the L48 base engine as they said performance difference wan't that great between the L48 and the L82.
They noted the L48 ran smoother and cooler.
The L82 idled rough and was only mariginally faster in the quarter mile and it had a higher gear ratio!
This was in
MAG-ELLE-O-MANIA, High Performance Cars, September 1973
Anyone out there had a 73 L82 and a 73 L48 and noticed major difference?..because sometimes SOTP can be a factor in engine characteristics.
Gary
Get the L-82.
Roger
So I know different mags had different times but this one raised my eyebrow. LOL
Good to know.. I have to put either my 454 or build a 383 stoker for my car.I want to keep the matching numbers engine which runs great intactand not kill it. LOL
L48s go back to '69 or '70 on Corvettes as the base engine - there are slight differences from year to year w/ both engines. W/ a rebuild the whole question often becomes more academic than anything else. Today there are better cams than either the L82 or L48 stock cam for example. Simply saying the L82 cam is 'better' ignores the fact that the L48 cam produces more torque at a lower RPM - which for some folks is more important.
-Mark.
I have the 454 already with rect port heads and the LS6 Low rise dual plane manifold. (hard to find item) or go with a light weight small block?
I'll decide for the next couple of months, because when April hits. I'm itching for a project to bestow between my Vettes fenders. LOL
Any suggestions? I was thinking the stroker 383.
-Mark.
L48s were optional engines in Camaros, Chevelles, Novas and a few others. However L48s in Corvettes had different carburetion calibration, air cleaner and exhaust and possibly different ignition advance curve map.
Mark - which models/years Chevrolet station wagons were the L48s available in?
Station wagon engine is not far from the truth from a functionality standpoint. They both use the same "929" cam, they both use the same connecting rods, the same cast aluminum dished pistons, the same cylinder head castings with the same small valves, no chamber unshrouding, the same engine case (block), the same cast iron crankshafts, the same small balancers, and the same shallow groove pulleys. There are differences in the intakes mostly because of the hood on the Vette being so low that it needs to be shorter than the intakes used on other cars. The carbs and distributors are calibrated differently but not because they wanted the Station wagon to be slower but because they are different in application only. Maybe the L-48 got the truck timing gear setup but who knows? That would not be a big difference here. For any year after 74 they both had cats.
LT-1 for a '70 Vette is different from the LT-1 in a '70 Camaro but not by much.
True, they do not have the same engine suffix code. If they did, they would be exactly the same assembly. Even so, these are both functionaly equivalent in terms of strength and hot rod potential.
-Mark.
THe L82 rods, as I said before, come from the same pile - but they are of course fluxed/peened.
Uh no, not all L48s got dished pistons. Nor were dished pistons exclusive to L48s. You may be surprised to find some dished pistons a little 'closer to home'. Some L48s have higher CRs than L82s. Arguably some folks feel the forged pistons may be a liability due to potential piston slap in the long term.
Just what are we supposed to look for that proves anything when we 'look' at the cats on an L48 as you previously suggested?
Mark, I think the information you have presented on L48s and L82s is A) simplistically dismissive, B) overly generalized and C) does not recognize the tradeoffs between high RPM HP and low RPM torque. Each has merits with notable trade-offs and each should be considered as a whole package, it's intended usage and year by year differences.
