Protect That Paint Job
Believe it or not, youll have a NICER quality, better looking, longer lasting paintjob without a clearcoat.
Think about it, what are you doing when you try to buff out a clearcoat scratch? Youre just swirling around more clearcoat, not the actual paint. If its JUST pain, every time you wax and polish it, youre doing so directly to the paint, not some layer of clear crap that gets scratched up and dull.
Youll have to wax, polish and care for a 0 clearcoat paintjob 2 or 3 times more than a clearcoat job, but I can promise you the results are well worth it.
BTW it will cost you more as well, because the general rule is you put extra layers of paint on a car without a clear to the tune of 1 layer of paint for every layer of clear that ould have gone on.
[QUOTE]
i seriously doubt that. Not trying to give you flack, just disagreeing. If longer lasting paint jobs didn't involve clearcoats, then every manufacturer wouldn't put bc/cc on their cars. Nicer quality, no way...nothing looks better than a wet, deep clear coat.
No matter what, your finish especially with clear, is going to have those small scratches..the key is to disguise them well with buffing and polishing. Example, Zaino Z5 does very well on hiding scratches by putting the polishing scratches in one direction so that they aren't as noticeable.
If the scratches are deeper, you need to touch up the paint, harder, but possible..
Assuming you have minor washing scratches, once you do buff them out you can keep them from happening again by always washing / waxing in a linear motion.
Front of the car to back.
straight lines always.
You see it's the circular motion of washing that makes cicular scratches and circular scratches can catch the light from any angle, while straight scratches can only catch the light from one angle...makes them much less obvious.
The whole point of clearcoat is to protect the paint. The paint is not exposed to the elements and the clear provides a UV protection.
Also modern paint must be clearcoated, otherwise it is flat. Of course if you grandfather has some leftovers in his basement...
For best results wax should be applied to the whole car in the shade on in the garage and left on for hours, I try for as long as possible then rub the residue off with a soft cloth in straight lines only.
Any other way and you create swirls, it can be applied in swirls without ill effects but not removed.
I believe you are completely wrong.
Something Id heard from an old mechanic buddy of mine, it made sense at the time, and I still think there is truth and examples (If I can effing well find one) where this has worked. There is a reason that there are still non clear coat polishing compounds avaliable...if everything was, they wouldnt sell the product. Basecoats are als quite durrable and have UV protection built right into them, of course they are more expensive, but probably well worth it. As for it being dull...hahaha clearcoats get dull too. In fact a high fleck paintjob kept abraisivly polished and waxed without a clear will probably shine just as brightly and deeply.
Base Clear can not be used without applying the clear. The base is very dull and not meant to stand alone.
Assuming I understood your post correctly and you in fact dont have a clear.
That's just silly. It's a totally different (and more expensive) paint. BC/CC was for the wrecked Camrys and Tauruses. Also for the first hose down of your car, the best sponge you can use is your bare hand. You'll be able to feel the grit and will be less likely to rub it into your paint. Then once you have all the big nasty crud off, you can hit it with the real sponge and soap.
