Balancer hub slippage
Anyway, I thought it would be interesting to some to see just how much a hub can rotate, so I placed the new and the old units side by side and took a picture.
Both hubs are placed so that if installed on a crankshaft, TDC would be facing straight at you. As you can see on the one on the left (the original), the timing mark is off significantly. I painted the white dot to represent where the TDC mark should be. So you can guess what one of the reasons was for this engine to be "running rough" when I purchased it. Even if a mechanic had set the timing to specs, with this balancer, it was off by at least 20 degrees.
The moral of this story is to always expect the unexpected and you won't be disappointed. Hopefully, this is a good illustration for those who have never experienced a slipped hub.
Steve
Another alternative is to buy a balancer cover from Jegs or wherever for about 35 bucks. The cover bolts over the whole thing and is held in place by the 3 bolts on the inner portion of the balancer which is keyed to the crank.
