Standard 9 leaf or 7 leaf metal spring?
Old Oct 15, 2004 | 10:12 PM
Garson's Avatar
Garson
Default Standard 9 leaf or 7 leaf metal spring?
I am rebuilding the front and rear suspension on my 74 coupe small block this winter. I already have the 460 lb. grand touring coils for the front. I do not have the 3 inch clearance from my exhaust to the rear spring as recomended by VBP so I am going with a metal spring in the rear. Is the 7 leaf f-41 rear spring to stiff or should I go with the standard 9 leaf. I would like to match the front as close as possible. I do not mind a stiffer ride if it will help the handling. I will aslo replace all bushings with poly along with new strut rods. I am running the KYB Gas adjust shocks.
thanks,
Garson
Old Oct 15, 2004 | 10:14 PM
Contrail's Avatar
Contrail
I'm running the 7 leaf on mine and I love it. It is firmer, but I don't think it's too harsh.
Old Oct 15, 2004 | 10:55 PM
R. Bruno's Avatar
R. Bruno
Old Oct 16, 2004 | 09:00 AM
Red73's Avatar
Red73
Old Oct 16, 2004 | 09:37 AM
gdh's Avatar
gdh
When I needed to replace the rear spring, originally a 7 the only one my mechanic had at the time was a 9 leaf. I quite like it for long cruises especially on the back roads. I have 550 springs up front with Bilstein's all around and the ride is very good.
To Standard 9 leaf or 7 leaf metal spring?
