Engine Change
Old Oct 17, 2004 | 09:28 AM
Car304's Avatar
Car304
Default Engine Change
I am thinking about replacing the engine in my 75 with a 383 stroker. How much should I expect to pay to have the old engine removed and the new one put in.
Old Oct 17, 2004 | 11:34 AM
marshrat99's Avatar
marshrat99
The engine change is not all that complicated thing to do. Suggest you get a quote from your local Chevy dealer. This quote will probably be on the high side compared to an independant, reputable mechanic. However this would be an excellent DIY project given that you've got a little mechanical ability, a couple of buddies, access to a garage and the proper tools. Tools would include an engine hoist, set of wrenches (1/2", 9/16" and 5/8" used mostly) and torque wrench. An experienced mechanic should be able to pull the old engine in 2-3hrs and installing the new one should be in about 4hrs. As a DIY project, give yourself a couple of weekends if cold beverages are involved.
Old Oct 17, 2004 | 03:00 PM
Red_Shift's Avatar
Red_Shift
I was charged $526. But I feel I was a little taken on that price. I feel a shop should be able to do the swap in no more than 5 hours tops.
Old Oct 18, 2004 | 03:37 PM
jcswm's Avatar
jcswm
I looked it up in Alldata to replace the short block ONLY
Man trans=25 hours
Automatic=20 Hours
Sounded High to me so I looked in Mitchell's .... SAME times
Most Quality shops around here charge $80. per hour
Old Oct 18, 2004 | 04:30 PM
75rag4sp's Avatar
75rag4sp
20 Hrs!!!!!!! that is 2.5 full work days. It may take me that...but I'm including at least 2 trips to the auto parts store to replace whatever it is I'm gonna break plus reduing at least one part of the project twice cause I screwed something up. It should take a mechanic half that Max!!!!
Old Oct 18, 2004 | 05:19 PM
Gordonm's Avatar
Gordonm
Back in the early 80s when GM had the wonderful deisel engine I did many a long block swap. GM would supply the long block and the customer paid the labor. They would give me 20 hrs to do the job. After about 3 or 4 of these I got it down so I could do it in 8 hours completly by myself. That was driving it in at 8 AM and driving it out at 4. That included engine removal swapping all the components over and reinstalling. If they charge you 10 hrs that would be fair time. There is always some problem that crops up. Personaaly I would not trust anyone but myself to do a swap. You will almost always find something that they short cut on the job. After all they are trying to make time on the car so they get paid well. Do it yourself even if it takes 100 hrs you will know what has been done and it will be done to your satisfaction.
Old Oct 18, 2004 | 05:31 PM
jcswm's Avatar
jcswm
Ummmmm..... I Am a Mechanic...... At A chevy Dealer
If I get to work at 7:30 or so and ALL Required parts are on hand.... I can have a few cups of coffee, a few cigarette breaks (Can't smoke in an air conditioned shop) And If I try to get back from lunch on time, If everything goes smooth I'll be done long before 5!!
Old Oct 18, 2004 | 05:33 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I wish one of you guys were my neighbor.
Old Oct 18, 2004 | 05:41 PM
jcswm's Avatar
jcswm
It's not a hard job
just climb under the hood & pull the motor out!!!
Old Oct 18, 2004 | 05:45 PM
billlambeer's Avatar
billlambeer
well..i have torn out a few engines..no sbc's until about 4 months ago..and by all means..i am no master mechanic..im decent..but not all knowing..the first time i tore my sbc chev out..it took a day..to get it out...and tear it all the way down to take to the machine shop..starting at 9 done by 6..so i would assume that someone that really knows what they are doing..could definitly get the engine dropped in a day..i bet i could pull an engine with one other person..and drop one back in and connect everything assuming the engine is waiting for me..in a day to a day and a half..hope this helps..lol
Old Oct 18, 2004 | 05:51 PM
1970-Bronze's Avatar
1970-Bronze
You sure you don't have hours and weeks confused.......
Everytime I turn around I have to order something that I need to finish.....My garage looks like a Summit warehouse from all the boxes laying around.
Old Oct 18, 2004 | 05:58 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by jcswm
It's not a hard job
i see the problem with your car....you've got the wrong engine in it... you need the model from "not a c3 but a lovely moon"...
Old Oct 18, 2004 | 06:23 PM
jcswm's Avatar
jcswm
Actually I have a better C3 Moon picture of my girlfriend in a T-bar ....same pose.... but no Babes section to upload to!!
Old Oct 18, 2004 | 06:25 PM
Summerfun's Avatar
Summerfun
It's not a hard job
When your wife shuts the hood on you, do you go..."VRRROOOOM"???
Old Oct 18, 2004 | 06:34 PM
jcswm's Avatar
jcswm
I'm Single!!!
For what it's worth that pic was taken 2 weeks ago
I drove her to work all last week & to a cruise in sat.
See my signature for all i did!!
To Engine Change
