Setting valve lash?
Old Oct 18, 2004 | 04:01 AM
Vesa's Avatar
Vesa
Default Setting valve lash?
Haynes manual gives basics for the procedure - guess it is ok to follow that. But they have no info on precs. My is 396 BB, with mechanical cam and crane gold race roller rockers. Any advice+
I did the seach and found 2 topics that were close and gave some help but any more advice would be appreciated!!!
Old Oct 18, 2004 | 05:42 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I used Gordon's method here:
http://forums.corvetteforum.com/show...ghlight=simple
Old Oct 18, 2004 | 06:41 AM
Vesa's Avatar
Vesa
Originally Posted by Jughead
Thanks! If I remember correctly - Gordon´s is the same as in Haynes - must read the haynes in the evening again, good to know that it is a accurate one as well. So I must measure the balancer and mark the 180degrees on it (I do now only have the original mark on 0 degrees and other made by me on 36 degrees).
Any opinions on right lash spec?
Old Oct 18, 2004 | 07:13 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
You'll open a whole can of worms with that question. I think it depends on your cam manufactuer. Mine was listed as 0.022, I've seen people post lower here on the forum. I did have it looser at 0.026-0.028 during assembly and break-in.
Old Oct 18, 2004 | 07:19 AM
Gordonm's Avatar
Gordonm
Follow the cam manufacters recomendations on valve lash. You can usually go a couple of thousandths either way of the recomendations. I would not stray to far from them. I got my procedure for valve lash from the GM service manual.
Old Oct 18, 2004 | 07:22 AM
Vesa's Avatar
Vesa
You and Jughead found the weak point here - I do not have a clue what kind of cam I have in there...I do know it puls eagerly past 6500rpm and idles 700rpm but quite rough...
Old Oct 18, 2004 | 07:50 AM
bracketshark's Avatar
bracketshark
Default valve adjustment
Here's how we adjust valves on our super truck, small and big blocks should be the same; Just as the exhaust valve starts to open, adjust the intake valve (on the same cylinder), when the intake valve is almost closed adjust the exhaust valve (on the same cylinder). I would use the manufacturers recomended lash requirements.
Old Oct 18, 2004 | 08:00 AM
Summerfun's Avatar
Summerfun
That's how I do mine!
I figured it must be wrong when I read that post with the mathematical
way to do it......which I will most certainly never remember because I don't do it often enough.
One winter and all that is forgotten
Old Oct 18, 2004 | 10:06 AM
bracketshark
Default valve lash
OOPS, I just re-read the post and you don't have the cam info. Ours set at .014 intake and .016 exhaust. I would not dare say that this would be correct for your cam though.
Old Oct 18, 2004 | 10:10 AM
Gordonm's Avatar
Gordonm
That is going to be kind of tricky not knowing what you have. What is it set at now. Most cams are either in the .024-.028 range or the tighter lash is around .014 to .016 range. Check to see what you have on a couple of the valves and compare them all. You should have an idea of what it should be by that.
Old Oct 19, 2004 | 01:14 AM
Vesa's Avatar
Vesa
OK - that is maybe the safest way - I will check a couple of them before start adjusting them
After reading all sources of info I think I will go with:
Compression stroke at
TDC #1 - 8E, 2I
90 deg. - 4E, 1I
180 deg. - 3E, 8I
270 deg. - 6E, 4I
0 deg. - 5E, 3I
90 deg. - 7E, 6I
180 deg. - 2E, 5I
270 deg. - 1E, 7I
...because I have no clue on my cam profile and this should be safe even with very long ramps as well...
Here is the whole thread where I got that info:
http://forums.corvetteforum.com/show...ing+valve+lash
Old Oct 19, 2004 | 12:33 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
http://www.totalengineairflow.com/tech/valvelash.php
Old Oct 19, 2004 | 02:14 PM
desi's Avatar
desi
Good info. Thanks. I will be needing it this winter
Old Oct 20, 2004 | 03:27 AM
Vesa's Avatar
Vesa
Ok - last night I did some work. The engine was totally cold (it was raining and I did not wanna drive on wet street and mess my vette). Most of the valves vere between 0.2 and 0.24 maybe 4-5 were out of that range - maybe 0.04 out - so I did adjust them. Also I noted the intakes were closer the 0.2 and exhausts closer the 0.24 so I followed that and set all intakes somewhere close 0.21 and exhausts somewhere close 0.225.
First impression is that the idle is a bit more stable...
Later today I will check some of them with hot engine to see if there is any difference and a need to readjust.
Anybodu having experience if and how much they normally differ (hot vs cold engine).
To Setting valve lash?
